Author Topic: Harley narrowglide hub+cb 550 wheel? Possible?  (Read 2255 times)
Offline shinneh
« on: December 08, 2011, 09:28:36 AM »
Welp, I've looked all over the internet/forums for the past few days to find the answer to this question: can I spoke harley's 19 inch narrowglide hub to my stock 550 wheel? I've read alot about people using the stock honda hub and mating it to a harley wheel, but I want the other way around.
Thanks guys for any input, once I get this sorted out I'll prolly start my build blog.
Our greatest glory is not in never falling, but in getting up every time we do.
-Confucius
Offline luap
  • LAWL
Re: Harley narrowglide hub+cb 550 wheel? Possible?
« Reply #1 on: December 08, 2011, 10:32:38 AM »
 looking at my narrow glide wheel 550 rotor wont work, running a harley rotor looks like it would run to wide for the stock 550 legs, an is the harley rotor compatible with the 550 caliper?   , but the wheel I have I bought complete little wider then the honda wheel. also have to call all balls an see if they  have a od bearing to fit harley hub an id to run the same stock cb axle
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline shinneh
« Reply #2 on: December 08, 2011, 10:38:49 AM »
Guess I should mention a little bit more. I asked specifically about mating the harley hub to the honda wheel because I am using an aftermarket fork setup (yamaha r6). I've read that one is best off using a harley wheel/hub with said front end in order to keep with spokes. As for bearings, I already know I'm running a gsxr bearing in the harley hub to fit the yamamha axle. I just want to avoid buying another wheel and use my honda wheel =P.
-Confucius
« Reply #3 on: December 08, 2011, 10:54:09 AM »
 The older H-D hub is 3/4 inch axle with tapered roller bearings, they may be on inch axles now. they use a 5 bolt flat rotor.
Thw bearing bores for the tapered races are in the neighborhood of 1.965ish diameter, if you are thinking of going to rgular bearings.
 Lots of take-off wheels,just get a whole wheel.
Offline shinneh
« Reply #4 on: December 08, 2011, 11:27:41 AM »
Welp, what you said doesn't really answer my question but are you suggesting to just get a whole wheel that fits my harley hub?
-Confucius
« Reply #5 on: December 08, 2011, 09:23:51 PM »
Hd wire wsheels are drop center rims Honda rims are not, if you rather spend 100 bux on spokes and lace it up ..fine
..rather than buy a whole wheel for 100 bux or less..
Offline crazypj
  • I'm brill, me
« Reply #6 on: December 08, 2011, 09:47:46 PM »
HD hub is 'smooth' but it's pretty heavy and bearings/axle don't fit forks without modifications.
If you just want a 'pretty' hub, look at factory customs from Honda (even the 250 rebel would probably work)
 I have a couple of HD hubs and  5 bolt rotors I was going to use on Yamaha XS650 but decided to use stock cast wheels instead (may modify one to use on rear though)
« Reply #7 on: December 08, 2011, 10:09:46 PM »
Shaved stock hubs look pretty cool polished or chrome...imo..
Offline crazypj
  • I'm brill, me
« Reply #8 on: December 09, 2011, 07:39:58 AM »
Yep, I did a CB360 one last week, posted a pics in someone else's thread   ;)
http://forums.sohc4.net/index.php?topic=99090.msg1105262#msg1105262
Offline shinneh
« Reply #9 on: December 09, 2011, 03:49:01 PM »
Ah, that clears it up. Thank ya 754-I was not aware of differences in hub styles. So then it definitely makes sense to just get a wheel. I rekon that concludes the need for this post, and begins my need for an hd wheel.
Thanks again~
-Confucius
