Author Topic: Cheap rubber mount bushings...  (Read 2887 times)
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« on: December 09, 2011, 10:03:11 PM »
...i.e. the little metal sleeve that goes in some rubber pieces to keep the fastener from crushing the rubber, like in the K model's rear turn signal mounts. I did this on Frankenbike last night, as I was sick of looking at squished rubber.
 All you have to do is get a 12X6.8 ring terminal, and cut the crimp part to length. You may have to spread it a little depending on your fastener size. Also, don't forget to de-burr after cutting! The cutting went easy, as the ones I got were brass plated in white metal.
Checking the bolt fit
After the cut
In the rubber
Hope this helps
Gonzo
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
