Author Topic: CB650 cam specs?  (Read 9344 times)
Offline Scott S
CB650 cam specs?
« on: December 10, 2011, 06:43:19 AM »
 I've searched and searched and just can't find all the cam specs for these cams.
Here's what I HAVE found:
SPECS:
 Stock (1974) CB550 cam
1.36 exh.       lobe              1.38 in.
1.110           base circle       1.110
0.252              lift              0.272
CB650 cam
1.39 exh.       lobe               1.40 in.
0.280             lift                0.293
 Can anyone give me the duration?
 What ratio are the rocker arms?
 Are the CB550 and CB650 durations the same?
« Last Edit: March 02, 2017, 11:56:33 AM by Scott S »
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
Re: CB550 cam and rocker specs?
« Reply #1 on: December 11, 2011, 06:07:05 AM »
 Anyone?
'71 CB500 K0
'81 Yamaha XS650
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #2 on: December 11, 2011, 10:40:12 AM »
I'll subscribe.  I only know 'seat of the pants' differences   8)
I do know there are two versions of the 650 cams.  IIRC, the earlier '79-'80 cams are hotter than the later ones.  Someone else mentioned all the German market cams are the wimpier, emissions restricting version.
« Last Edit: December 11, 2011, 10:41:45 AM by Greggo »
Offline Scott S
« Reply #3 on: December 11, 2011, 11:16:10 AM »
 I think all the '79-82 CB650 cams are the same EXCEPT for the low HP German versions.
 I can't believe I'm having such a hard time finding these specs. I have a factory manual, aftermarket books, have searched this forum, etc.
 I'd really like to know:
-CB550 duration
-CB650 duration
-stock CB550 rocker arm ratio
'71 CB500 K0
'81 Yamaha XS650
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #4 on: December 11, 2011, 07:51:58 PM »
I don't have the answers you want, but there's a "contact" link here. They might have the standard specs you're looking for seeing as they do grinds for them.
http://dynoman.net/engine/cams/webcams_honda.html
Good luck.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Scott S
« Reply #5 on: December 12, 2011, 02:32:48 PM »
Some good info a fellow forum member sent me in a PM. Thanks Kemp!
Here's the info I have on the CB550/650 cams. Unfortunately I do not know the rocker arm ratio and have not seen that info published. Would like the answer to that question also. The text below is cut and paste from articles and notes from others on the forum.
OK I found specs for Yosh cams.
Street special part# YH500-121-00
IN opens 20 BTDC, closes 50 ABDC  .278 lift
EX opens 50 BBDC, closes 20 ATDC  .307 lift
TT Special race cam  #YH600-122-00
IN opens 27 BTDC, closes 57 ABDC  .324 lift
EX opens 56 BBDC, closes 27 ATDC  . 336 lift
From another post, the lift on stock cams is:
CB650    IN .280
            EX .293
CB550    IN .252
            EX .272
It looks like the 650 isn't too far the Yosh street cam as far as lift, not sure about timing?
In corresponding with hymodyne I guessed the 650 cam would have about .020 more lift than the 550 cam. Kayaker's #'s say I was close. I also guessed about 10 degrees more duration at least on the intake.
think .030 or so more lift would have a miniscule effect on ramp angle, but more duration would add to it. No matter what, lift is good, but its the timing that matters. The most important timing event as far as "feel" is intake closing. Closing later moves power up the rev range because it gives more time to fill at high revs.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #6 on: December 12, 2011, 06:41:41 PM »
I was also given some specs for the stock CB550 cam from a 1980 Action Fours catalog:
 intake duration 240*
 exh. duration    245*
 intake lift     .300
 exh . lift       .280
 Using the numbers I posted earlier, this would give me a 1.1:1 rocker ratio, right? (.300 divided by .272 equals 1.10. Using the same math for the exhaust side gets me 1.11.)
 That would mean the CB650 cam has .322 intake and .308 exhaust lift at the cam, right? (And possibly more duration)
 Those kind of lift numbers put me in the FK10-ish  or larger range, right?
'71 CB500 K0
'81 Yamaha XS650
Offline Danno
« Reply #7 on: December 13, 2011, 11:08:47 AM »
the 650 cam has a slightly higher lift and about 8 degrees longer duration it is great for the 550 as a modest performance mod but the cam tunnel has to be modded a little an extra groove added to use it and you have to use the 650 tach gear
« Reply #8 on: December 13, 2011, 11:55:52 AM »
a while ago i degreed a 500 to find out the timing specs,ive got it written down somewhere,ill dig it out.
« Reply #9 on: December 13, 2011, 12:34:46 PM »
at 40 thou i came up with
ex37/2 lift 279 dur 219
in5/31 lift294 dur 216
Offline Scott S
« Reply #10 on: December 13, 2011, 12:58:41 PM »
 Dave, can you clarify those lift #'s? 37/2 and 5/31?
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #11 on: December 13, 2011, 01:01:34 PM »
 I have the 650 cam lift #'s, just trying to find the duration. So...add about 8  degrees to th 55o duration?
 What do you mean by "cam tunnel"? I clearnced the head to clear the 650 cam already. Will check rocker cover soon. I have the tach gear, but what do you mean by "an extra groove added"?
'71 CB500 K0
'81 Yamaha XS650
« Reply #12 on: December 13, 2011, 01:06:14 PM »
37/2   5/31  this is at 40 thou,some numbers from where ever may be at zero lift .
« Last Edit: December 13, 2011, 01:08:02 PM by dave500 »
Offline Scott S
« Reply #13 on: December 13, 2011, 02:17:59 PM »
 I don't know what the 37/2 and 5/31 mean....
 Also, our lift specs are pretty close, but the duration #'s are different.
'71 CB500 K0
'81 Yamaha XS650
« Reply #14 on: December 13, 2011, 03:53:12 PM »
the 5/31 and 37/2 refer to the opening and closing points in degress like inlet opens 5 btdc and closes 31 abdc,exhaust opens 37 bbdc and closes 2 atdc,,these arent gospel figures,just what i came up with tinkering,measured at 40 thou lift,if you do it with no lift and clearance the numbers change significantly,cars are generally measured at 50 thou and bikes at 40 thou.
« Last Edit: December 13, 2011, 04:25:11 PM by dave500 »
Offline Scott S
« Reply #15 on: March 02, 2017, 11:50:15 AM »
 Bumping this one up. I'll be taking a stab at degreeing in a 650 cam soon (milled the head and I just want to learn how to do it and maximize the engine combo), and I'd love to find any more information, if possible.
 Specifically, anyone know the duration and/or timing events? Like what Dave listed above for the 500 cam?
'71 CB500 K0
'81 Yamaha XS650
Offline jbraun
Re: CB650 cam specs?
« Reply #16 on: October 14, 2019, 12:23:08 AM »
Im far away from you guys in knowledge regarding this, just been starting to scrape on the layer of knowledge around swapping the cam from a CB650 into a CB500. Been trying to get the info if its a clean swap or do I need to do anything more?
« Reply #17 on: October 14, 2019, 01:22:14 AM »
the cam is a clean swap providing you test it first by laying it in the rocker cover and turning it and check if lobes hit anywhere,if so you can buzz that off,also check the lobes don't hit the underside of the actual rocker arms,do the same in the head,lay it in and rotate it to see if the lobes foul anywhere,youll need the 650 tacho drive gear aswell.
« Last Edit: October 14, 2019, 01:23:57 AM by dave500 »
Offline jbraun
« Reply #18 on: October 14, 2019, 03:15:40 AM »
Sweet! Thanks for your answer!
Sorry for stealing the thread  :P
« Reply #19 on: October 14, 2019, 07:19:01 AM »
650 cam requires a tach instrument change to same ratio of either 650 or 750...keeping in mind the high 550 redline band starting at 9500 rpm.
Offline flatlander
« Reply #20 on: October 14, 2019, 08:34:55 AM »
not only tach instrument (clock) but you also need to change the tach gear.
« Reply #21 on: October 14, 2019, 03:54:21 PM »
Yeah, Dave had already mentioned that...
Offline jbraun
« Reply #22 on: November 05, 2019, 11:30:13 PM »
Hi guys! Just one more question :P do I need to change anything else in order to get it working? Stiffer springs maybe?
Offline Scott S
« Reply #23 on: November 06, 2019, 02:54:26 AM »
 The 550 springs are fine.
'71 CB500 K0
'81 Yamaha XS650
Offline jbraun
« Reply #24 on: November 06, 2019, 03:35:31 AM »
I have a 500 tho, still the same?
