Author Topic: Cam breather cover bolt stuck  (Read 1767 times)
Offline buffaloejon
« on: December 10, 2011, 07:32:04 AM »
Is this bolt a trick or something? Destroyed the head as you can see... got the other two loose first, this one is in there so good it warped the bit on the impact driver...
So now what? Machine shop, cause I can't stand to mess with it?
Edit forgot pic
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
76 CB750K
http://photobucket.com/buffaloejon
Re: Cam breather cover bolt stuck
« Reply #1 on: December 10, 2011, 07:36:13 AM »
Nothing trick about it,just stuck I quess. Try some heat and all the other tricks first and worst case scenerio you can drill of the head and grab whats left after cover comes off with some vise grips or such.Should be a lot of thread left.
Offline Grabcon
« Reply #2 on: December 10, 2011, 09:26:49 AM »
It appears the motor is out of the bike so working on it is easier. When the stock philips screws strip when removing I always use a hand electric drill with a drill bit the size of the screw, not the head. I use light pressure and drill straight into the head. I find that just before I drill through the head the tension on the screw is relieved and I can then unscrew the screw. If not keep drilling until the head pops off. Remove the cover and then unscrew the remainder of the screw.
I have used this technique many time, not only for the side covers and such, but also for things like the cap screws in the bottom of the forks, etc.
Patients is key and a sharp drill with a vari speed hand drill.
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline luap
  • LAWL
« Reply #3 on: December 10, 2011, 09:31:48 AM »
Try some vise grips with some heat mentioned above, an worse case drill it out
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline buffaloejon
« Reply #4 on: December 10, 2011, 10:44:35 AM »
Well, impatience won out here. Long story short, I'm gonna need some JB Weld, or a new cam breather cover.
But, the screw was REALLY easy to get out once the breather cover was off, and I hardly had any thread to grab on to. Which makes me really wonder why it was stuck. The PO must have tightened the ever loving **** out of it.
76 CB750K
« Reply #5 on: December 10, 2011, 11:09:36 AM »
What is often not realized is that these cover screws don't stick at the thread level. The stick occurs between the bottom of the head of the screw and the cover it is holding down. If you can get the head of the screw off, by drilling or grinding, the cover will come off over the stump of the screw and what's left of the screw will (usually) thread right out.
The science of this is that the screw is steel and the cover is aluminum. The part that is exposed to the elements, the screw head, undergoes a chemical reaction with the cover and bam, its stuck. Often has nothing to do with how tight the screw may have been tightened. Simply a matter of time and exposure to the elements.
Offline buffaloejon
« Reply #6 on: December 10, 2011, 11:24:03 AM »
Well, that makes sense for sure. I'm gonna work on finding some stainless allens to replace all these phillips, they're all so old they just strip if I look at too hard.
But in other news, I got what I needed to do done.
76 CB750K
« Reply #7 on: December 10, 2011, 12:59:44 PM »
The same if not worse chemical reaction occurs with stainless. The fix is a dab of an anti-seize compound when installing them. Stainless is not necessarily stronger than OEM either, just prettier. Strength in this rea is not a concern.
Look in FAQ for parts suppliers. There is a forum member who sells stainless screw kits as well as many commercial suppliers.
« Reply #8 on: December 10, 2011, 01:54:15 PM »
Didn't Honda put plated copper washers (or at least plated washers) under those screw heads?  I speculate it was to avoid the chemical reaction between the screw head on the alloy cover.
It's those "little things"...
Of course, what's handy or available at the local HS is "cheaper" and "works" short term.
