Author Topic: Coil Meltdown  (Read 5533 times)
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
Coil Meltdown
« on: December 10, 2011, 07:04:13 PM »
Just as I set off to complete my handover leg on the SOHC relay today...one of my coils spat black goo in a cough and spit and smell of hot burning rubber. So in a panic I had to swap over to the non-SOHC Triumph to hand over Godzilla.... :'( >:(
So now I have only the 1 & 4 coil working. Having pulled out the coils - I can see the black goo oozing from the other coil - so it's toast.
Can I call on my SOHC brotherhood for advice here...am I stupid to buy just ONE coil - say a new EMGO or similar? Do I really have to I buy a matched set - new EMGO or similar? Or go for used originals. I can only find one set used on fleabay - that's US$100. I can buy new repros for around US$35 each. Having deep pockets and short arms - I am tempted to buy ONE cheapo new coil..should I?
Look forward to some deep and meaningful discussion...well hoping..
Anyway - Godzilla has been handed over and details will be posted on that area on the board...
Regards
Mark
Offline Trav-i
  • Has finally become an
Re: Coil Meltdown
« Reply #1 on: December 10, 2011, 07:09:52 PM »
I would say consider a set of 5 ohm Dyna coils, and a set of their wires.  At least after that you'll have easily replaceable plug wires.
Forum member #9962
1992 GL1500 Interstate
Re: Coil Meltdown
« Reply #2 on: December 10, 2011, 08:32:02 PM »
I'm cheap, so I'd buy just one coil!  ;D
Re: Coil Meltdown
« Reply #3 on: December 10, 2011, 09:19:59 PM »
  Do you mean GZ traveled by other means than a SOHC../..MIGHT HAVE TO REDO THAT PART..
 iF YOUR CHARGING SYSTEM IS WIRED WRONG it can overcharge as it does not realize it should stop charging.. that can cause coil meltdown...
Offline nancy
Re: Coil Meltdown
« Reply #4 on: December 10, 2011, 09:51:00 PM »
Yes,,..sorry about that "754"...I'll happily redo the leg as soon as I get Hondy back on da road.
Incorrectly wired charging? Dunno..but nothing has been fiddled with by me in 2 years in the charging area.
Only thing I can think of - a year ago I did replace the HT leads after one fell off at the coil! So I may have introduced  a gremlin, fruit fly or blight maybe? Or....it was just it's time. :'(
Re: Coil Meltdown
« Reply #5 on: December 10, 2011, 11:09:44 PM »
I think your bike's probably fcuked mate, best send it to me so I can dispose of it safely. I normally charge for this service, but seeing that it's close to Christmas, I'll waive the standard fee in the spirit of the season......
But in all seriousness, don't buy a dodgy Emgo coil, you can buy a pair of new Dyna coils and leads reasonably inexpensively from Z1 Enterprises, so reach a bit deeper into your pockets and do something that will solve your problem and actually improve your bike's performance a tad.
Isn't it kind of ironic that you had to switch from your broken down Honda to your more reliable English bike? Haven't times changed.............. ;D
Offline Deltarider
Re: Coil Meltdown
« Reply #6 on: December 11, 2011, 12:07:21 AM »
Personally I never experienced any improvement by going dyna. Had one failing after 30.000 kms already. Being able to renew HT-leads is a good thing however. Just compare prices and then pick your choice.
BTW, could you have shortcircuited your coil?
CB500K2-ED Excel black
Re: Coil Meltdown
« Reply #7 on: December 11, 2011, 12:11:27 AM »
i have a good stock set you can have for $40,,the postage will kill it though?
Re: Coil Meltdown
« Reply #8 on: December 11, 2011, 12:29:51 AM »
That's a bit of bad luck mate, my Dyna coils are 12 years old now, and still working great. I removed a set of new OEM coils from my blue CB750 K2 and replaced them with some used 5 Ohm Dyna's and leads last Christmas and I couldn't believe how much brighter the spark was, and how much smoother the engine ran, even with points. I wouldn't use OEM coils in anything apart from a 100% original resto, they're like original shocks, original tyres etc, they're OK, but there are plenty of better options out there. Cheers, Terry. ;D
Offline Deltarider
Re: Coil Meltdown
« Reply #9 on: December 11, 2011, 08:05:05 AM »
My stock Honda coils that I keep in the basement still work great and I can't understand I didn't leave them on. Spending money on buying that third extra Dyna was a mistake. Should have returned to my stock coils when one Dyna gave up, but back then I was still too eager to believe Dyna was something special. I was projecting what I desired in it. Only advantage of Dyna is you can change the HT leads easily. This in itself can be a good reason. On the other hand NGK's cable coupler isn't a bad idea either (and much cheaper). Decades ago I could be influenced with this 36.000 Volts bla, bla.  Now I understand how things work, not anymore.
I've never experienced any gain of the Dyna coils (how could it ever?).
From cleaning your HTleads or a fresh set of plugs on the other hand, yes, definitely.
« Last Edit: December 11, 2011, 08:20:14 AM by Deltarider »
Offline nancy
Re: Coil Meltdown
« Reply #10 on: December 11, 2011, 11:51:52 AM »
Dunno how I would have rodgered it - so I guess,.the answer is no, I don't think I've short-circuited the coils. All has been running OK without any tinkering for months. Did rebuild the coils within the last year to insert new HT leads - so I guess I may have introduced a weakness. I have noticed for two years since buying the bike that #3 plug was sooty and I have rebuilt carbs, rejetted, changed clip heights, points checked etc...without much  change. So..maybe I have had a weak 2 & 3 coil for some time. Over the last week on starting,..#2 pipe would not warm up..so warning signs started.
Offline nancy
Re: Coil Meltdown
« Reply #11 on: December 11, 2011, 11:55:35 AM »
Thanks Dave - I may be interested...I haven't priced those Dyna coils that Terry wants me to look at...I'll look. I suspect they'll be 1 & 1/2 bills or so..so I will baulk at that cost this side of the silly season (well she-who-must-be-obeyed will). I'll look into postage costs to/from Gold Coast at this end....if I buy from a US site I'm still up for postage/courier costs.
Regards
Mark
Re: Coil Meltdown
« Reply #12 on: December 11, 2011, 02:20:58 PM »
Nancy as the cheapskate in my family I have decided to bite the bullet and replace the whole fooking ignition system. Throw out the failing Dyna, and put in a PAMCO, put new coils and wires. I am not pushing the #$%*.
Offline nancy
Re: Coil Meltdown
« Reply #13 on: December 11, 2011, 06:37:23 PM »
Yeh, well that's up there on price at $239US without shipping to me....but I agree that would be the solution I'd vote for. The little purse holder who-must-be-obeyed will see it from a different perspective if u catch my drift...
Re: Coil Meltdown
« Reply #14 on: December 11, 2011, 08:07:05 PM »
I hear ya Brother. This is my XMAS gift, I can;t ride the crap I usually get.  ;D ;D ;D ;D ;D ;D
Offline Deltarider
Re: Coil Meltdown
« Reply #15 on: December 12, 2011, 01:13:37 AM »
I wonder if any of those aftermarkets electronics are protected against moisture. Temperature varies behind that ignition cover and I wonder about condensation. That's one of the reasons I mounted my homemade transitor ignition module high and dry in a safe place, behind the strap of the battery.
« Last Edit: December 12, 2011, 02:53:20 AM by Deltarider »
Offline Deltarider
Re: Coil Meltdown
« Reply #16 on: December 12, 2011, 03:01:46 AM »
Oh... and here's another tip: use wire that is supple and will stay supple (silicon wire?)
After many years in use the wires of mine are rockhard and not pliable anymore.
pamcopete
Re: Coil Meltdown
« Reply #17 on: December 12, 2011, 06:28:45 AM »
http://www.cb750supply.com/products has two PAMCO kits somplete with coils. wires and caps. One at $175 and the other at $239, both with free shipping.
Re: Coil Meltdown
« Reply #18 on: December 12, 2011, 07:24:55 AM »
PETE, i bought one, please check your messages..
Offline nancy
Re: Coil Meltdown
« Reply #19 on: December 12, 2011, 12:26:31 PM »
Bobby - would like to hear how you get on - how hard, how fast, how cool...
Regards
Mark
Re: Coil Meltdown
« Reply #20 on: December 12, 2011, 12:32:05 PM »
Will do Mark. I am waiting for it to arrive. I will be insralling it replace a failing Dyna. I can give everyone a comparison of how they are installed. Ii may be moved to take pictures of the process.
Re: Coil Meltdown
« Reply #21 on: December 13, 2011, 01:35:42 AM »
Hey Bobby, wanna sell me that failing Dyna? Cheers, Terry.  ;)
