Author Topic: 500/550 cam chain tensioner  (Read 5844 times)
« on: December 10, 2011, 11:48:16 PM »
be sure you get the tensioner into its little locating well when you reassemble it,,ive just taken apart a 550 motor i just bought and found this,,the engine had been disembled for inspection then put back together and not run,,just as well.
along with a 61mm bore and no rings fitted save for about an eighth of a one piece oil ring and only one clip on each wrist pin.
« Last Edit: December 10, 2011, 11:51:15 PM by dave500 »
