Author Topic: CB550 cam and rocker specs (cross post)  (Read 3054 times)
Offline Scott S
« on: December 12, 2011, 02:30:49 PM »
 I posted this question in the SOHC4 forum, so forgive the cross posting, but I was wondering if maybe some of you Hi-Po guys might have the specs?
 I've searched a LOT and can't find them. Anyway, here's a cut and paste:
Here's what I HAVE found:
SPECS:
 Stock (1974) CB550 cam
1.36 exh.       lobe              1.38 in.
1.110           base circle       1.110
0.252              lift              0.272
CB650 cam
1.39 exh.       lobe               1.40 in.
0.280             lift                0.293
 Can anyone give me the duration?
 What ratio are the rocker arms?
 Are the CB550 and CB650 durations the same?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Bill/BentON Racing
    • BentON Racing
Re: CB550 cam and rocker specs (cross post)
« Reply #1 on: December 12, 2011, 03:03:04 PM »
Stock CB500/550 cam intake duration 240 ex 245.Intake lift .300 ex .280.Hope it helps...try and find a Yosh B grind or similar. My .02. Bill
« Last Edit: December 12, 2011, 03:32:47 PM by bellcow54 »
BentON Racing Website
BentON Racing Facebook
Offline Scott S
« Reply #2 on: December 12, 2011, 03:25:42 PM »
 Is that lift at the valve? Is that taking the rocker arm ratio into effect?
 Why do the specs I have show .272 vs. .300 on the ontake and .252 vs. .280 on the exhaust? If it's because of the rockers, that will make it easy for me to find the rocker arm ratio....
'71 CB500 K0
'81 Yamaha XS650
    • BentON Racing
« Reply #3 on: December 12, 2011, 03:43:37 PM »
Specs out of 1980 Action Fours catalog.Doesn't say how they measured.Bill
Offline Scott S
« Reply #4 on: December 12, 2011, 05:29:08 PM »
 If I divide the lifts you listed by the ones I have, I come up with a 1.10 or 1.11 rocker ratio. Sound reasonable?
 Does that mean the CB650 cam has .322 intake and .308 lift at the cam?
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #5 on: December 12, 2011, 06:27:40 PM »
 And, Bellcow, does the catalog list anything for the CB650 cam?
'71 CB500 K0
'81 Yamaha XS650
