I have a 78 cb750 that I thought of replacing the stock 30mm carbs with 29mm. Does anyone know if switching to the 29's will mean I can use the earlier carb boots? The 77 and 78 cb use those impossible to find carb boots. Basically are the different boots a product of the 30mm carbs or are the angles different on the actual engine block?
