Author Topic: im new here and new to SOHC\4 bikes  (Read 2280 times)
Offline L3niin
  • My First 500
« on: December 13, 2011, 08:34:55 PM »
thats my bike a 1971 cb 500 four ive done a ring job, valve job , new clutch plates and allot of other little things ..
i thought it was running right  but i started to hear a little rattle comming from what i think  is the timing chain, but it stops when i hit 4,000 RPM and always at 4,000 exacly in every gear ..
do you guys have any thoughts about it .. should i be woried
MyFirst cb500
cb550 77
Re: im new here and new to SOHC\4 bikes
« Reply #1 on: December 13, 2011, 09:09:16 PM »
gday L3,welcome,,your noise might be the rocker shafts worn in the cover?where the rocker shafts ride they wear the actual cover in an oval,to check the wear youll have to back the tappets right off,then with those end caps removed you can screw a 6mm bolt into that thread designed for pulling the shafts out with,,dont pull on the shafts but try and wiggle them up and down and round and round and see what you find,youl have to rotate the engine at some point as even with the tappets backed off one or two will ride on the valve and not let enough slack to wobble those shafts.
« Last Edit: December 13, 2011, 09:43:56 PM by dave500 »
« Reply #2 on: December 14, 2011, 03:30:54 AM »
Have you adjusted the valves?
Offline Lostboy Steve
« Reply #3 on: December 14, 2011, 08:09:43 AM »
Welcome... No idea what that noise is, but Dave seems to be spot on most of the time so I'd follow his diags.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #4 on: December 14, 2011, 10:35:45 AM »
I'm thinking he probably did that when he did the "Valve job" on it.... ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline mrbreeze
  • Not your average
« Reply #5 on: December 14, 2011, 03:00:43 PM »
Synch the carbies. If they're off....you will get that noise big time as the cylinders are fighting each other.
MEMBER # 257
Offline L3niin
  • My First 500
« Reply #6 on: December 25, 2011, 06:42:22 PM »
#$%* so much for trying to fix it .. i was heading to work .. and some guy just cut me off.. i T Boned the car and flying i went,
i havent really seen the bike i been at the hospital and well in bed i saw that the headers and the forks were bend carbs were moved and little stuff here and there i still dont know the reall damage on it i cant walk very much
broke my collar bone, 3 chpped ribs one swollen ass foot, missing skin on pinky ,but i was  wearing a healmet and im alive and i was super man for a couple seconds
MyFirst cb500
cb550 77
72500john
« Reply #7 on: December 25, 2011, 06:50:27 PM »
get well soon and keep us posted on your progress..our thoughts and prayers are with you!!
Offline 78 k550
« Reply #8 on: December 25, 2011, 07:25:16 PM »
Get well soon.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #9 on: December 25, 2011, 07:32:47 PM »
Get well quick. sorry to hear about your bike. Congrats on the superman. Flying is easy, landing is hard.
« Reply #10 on: December 25, 2011, 10:48:12 PM »
bad #$%*,get well.
« Reply #11 on: December 26, 2011, 05:26:58 PM »
Sorry to hear...........
Offline bjatwood
  • 1973 CB750-K3
« Reply #12 on: December 27, 2011, 08:10:32 AM »
Man "Clark Kent" that's bad news! But, there's another Lois Lane around every corner!  ;D
Keep the cape up, you'll be flying again in no time! (pun intended)
Brian
#24193
Offline CrankyOldGuy
  • Wish I was a
« Reply #13 on: December 27, 2011, 08:13:58 AM »
Take care ... wish you all the best in your recovery!
Harry O.
750 K1 Original Owner
« Reply #14 on: December 27, 2011, 08:17:14 AM »
No $hit!  Glad you ok, aspiring Clark Kent :)
Get better soon, your motorcycle needs you.
Offline L3niin
  • My First 500
« Reply #15 on: February 14, 2012, 06:04:50 PM »
Alright guy thanks for the support now im back in action..
so i saw my forks thous are total goners but the triple tree is still good..
 so i was thinking of putting a inverted system on the bike a friend told me about this brand Hyosung pretty inexpensive .. but im guessing i will need a new break system and something to hold the light and wheel i dont know if it fits or if it fits in the triple tree... you know i dont wanna buy them and don't FIT
well my question is is that a good idea?
 right now Don't Have the stock cb 500 i believe i have a suzuki GS 80's i believe is dual disk its ok ..
what do you guys recommend ? for the Forks
go to stock ? inverted ? back to the Suzuki ones ?
well the headers are bend also they touch the frame i dont know if it would be fine to run it like that if i had to ?
MyFirst cb500
cb550 77
Offline grcamna2
« Reply #16 on: February 14, 2012, 07:22:45 PM »
+1
75' CB400F/'bunch o' parts'
« Reply #17 on: February 15, 2012, 01:35:24 AM »
I would replace with stock so you know it will fit/work.  The front end off a 550 may also work.
Have you looked in the forcsale section of this forum?
« Reply #18 on: February 15, 2012, 02:15:51 AM »
Check the down tubes on the frame to see if they are bent, changing the headstock angle on the frame.
I know you don't want to think the frame is bent.  But it seems unlikely that the forks, would absorb ALL the distortion damage in a crash this bad.
Offline Bob3050
« Reply #19 on: February 15, 2012, 01:59:02 PM »
L3niin: From your pictures it's obvious the front end took a hard direct hit and because of that I would pull the steering stem (triple tree) and check it closely. I've seen many bent at the lower bearing area. Also check the lower bearing area of the frame for any distortion. Glad to hear that you're ok and good luck.
Bob
