Author Topic: Finished oil tank cb750  (Read 25250 times)
Offline VTEC
« on: December 13, 2011, 10:17:50 PM »
Hey guys can some one explain what this line? i planing on building custom oil thank and was wondering if i can plug this not use it? The engine is cb750 76k
« Last Edit: January 12, 2012, 07:24:12 PM by VTEC »
Offline Eddie
Re: Can i plug this?
« Reply #1 on: December 14, 2011, 04:06:17 AM »
yeah, you plug that and you'll have oil shootin out all over the first time you rev past 5-6K...
Offline VTEC
« Reply #2 on: December 14, 2011, 06:08:18 AM »
Ok guys wasn't exactliy sure what it was. I'll leaw it a lone
Hinomaru
« Reply #3 on: December 14, 2011, 12:33:24 PM »
VTEC, you can plug the rear crankcase fitting, but only if your custom oil tank has a means to vent. The oil tank cutaway pictured in your post does not show a vented design, this means that excess oil can only be relieved from the oil tank overflow to the rear crankcase fitting.
The crankcase is designed to flow from the rear crankcase oil fitting then up to the valve cover which vents vapors and blow-by to the atmosphere. This is easily checked by blowing air into the rear crankcase fitting.
Offline VTEC
« Reply #4 on: December 20, 2011, 11:06:15 AM »
Hey guys how much oil fits in original tank?
This what I'm going after
And here's  my progress
Offline gnarlycharlie4u
  • Far from being an
« Reply #5 on: December 20, 2011, 11:47:41 AM »
oh wow that looks GREAT!
Good job so far.
It's been said but I'd like to reinforce that you CAN plug the rear case vent but your oil flow may suffer because of it. I'd keep it. it's only a small, short line to run anyway.
Offline CB750K4
Re: How much oil fits in original oil tank?
« Reply #6 on: December 20, 2011, 12:46:32 PM »
3.5 qts?
When I change oil, I put three qts in the tank, run for short time then top off with forth quart.  Been doing that since I bought it in 1974, never any problems.
CB750 K4  (original owner)
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #7 on: December 20, 2011, 12:52:40 PM »
3.5 qts?
+1.
Offline ANVkevin
  • CB750K7
« Reply #8 on: January 10, 2012, 05:38:28 PM »
May be obvious but, I assume the lower crankcase vent should be routed into the tank at a level higher than the full level of the tank. Correct?
« Reply #9 on: January 10, 2012, 05:58:00 PM »
If you maintain the original purpose, no. The original setup has the crankcase vent (misnomer as you'll see) entering the oil tank below the level of the oil. That is because there is a pipe right there that travels up the inside of the tank and terminates in the condenser bulb at the top. Hence whatever is in that pipe never touchesthe pool of oil.
So if fumes travel up the pipe, dribbles of oil travel down the pipe and enter the crankcase through what we are are calling the breather. Those droplets of oil are deposited on a sheet metal pan about the size of a matchbook, and used to feed the chain oiler.
If you are doing away with the chain oiler, and just need a terminus for the crankcase hose, then yes you would want it above the oil level.   :D
Hinomaru
« Reply #10 on: January 10, 2012, 07:05:00 PM »
MC, did you know that the chain oiler was eliminated on the K6, which is what the OP has?  This chain oiler delete change resulted in a new crankcase design and new crankcase part number. The K6 oil tank also lost the condenser bulb and open vent hose to the atmosphere. With the new K6 design, any excess oil in the tank is returned to the engine via the lower crankcase vent fitting. Remember how an overfilled KO-K5 oil tank deposited oil out the upper oil tank vent hose and made a serious mess? I sure do.  8)
(click images for a larger view)
KO to K5 oil tank design:
New K6 oil tank design:
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #11 on: January 11, 2012, 06:35:42 AM »
So on the pic of the K0 to K5 design, the lower pipe is connected to the  rear of the crankcase, does the top pipe vent to the atmosphere? just making sure.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
« Reply #12 on: January 11, 2012, 06:53:12 AM »
Kevin
On the K0-5, yes.
« Reply #13 on: January 11, 2012, 06:58:40 AM »
Thanks Hino! That clears things up. I need to remember my "expertise" or experience at least, tapers off quickly after the K2. So as not to mislead.
I see from the cutaway of the later tank, the overflow is completely contained inside the tank.
Offline ttr400
« Reply #14 on: January 11, 2012, 07:02:58 AM »
Great. Thanks
Kevin
www.ttr400.com
Offline VTEC
« Reply #15 on: January 12, 2012, 07:23:10 PM »
Heres my finished oil thank, little less than 3qt fits
Re: Finished oil tank cb750
« Reply #16 on: January 13, 2012, 04:21:46 AM »
Pretty sweet, good job.
« Reply #17 on: January 13, 2012, 07:36:38 AM »
 NICE !!...
Offline greenjeans
  • 1972 CB750K2
« Reply #18 on: January 13, 2012, 07:49:46 AM »
Me likey.    Any plans to make a few more of those ?
Offline Really?
« Reply #19 on: January 13, 2012, 01:19:29 PM »
Yea, what greenjeans said.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline WhyNot2
  • I'm finally an
« Reply #20 on: January 13, 2012, 01:32:07 PM »
I'm in, I efing like that tank. And the overall look of the bike....
What year is it?
« Last Edit: January 13, 2012, 01:40:27 PM by budlite282 »
Offline Really?
« Reply #21 on: January 13, 2012, 01:33:27 PM »
I actually looked at those pics and was still wondering where the oil tank was.  I finally found it but not at first.
Offline VTEC
« Reply #22 on: January 13, 2012, 03:49:58 PM »
No plans to make more. I don't have right tools to do it more efficient at this moment
Took me some time to make it
My bike '76
Offline brandEn
« Reply #23 on: January 14, 2012, 01:27:33 PM »
NICE oil tank!
Offline tweakin
  • tear down
« Reply #24 on: January 15, 2012, 05:37:08 AM »
Nice work on the oil tank!  Hope to see your build in person someday.  Did you ever find a local machine shop to do the swingarm work for you?
« Last Edit: January 15, 2012, 05:39:26 AM by tweakin »
