Author Topic: Cb750 K0 -oil gallery plug under shifter cover?  (Read 17790 times)
Re: Cb750 K0 -oil gallery plug under shifter cover?
« Reply #50 on: November 02, 2017, 09:21:50 AM »
 I've had annoying leaks in that area and didn't consider that as a source. One more morsel of cb750 knowledge. Thanks for making these parts available. I have my brothers one owner K4 that leaks down into the case and then seeps out around the sprocket cover. Looks like it needs the oil pump kit, sprocket seal and while I'm in there, something to check.
« Last Edit: November 02, 2017, 09:24:02 AM by Don R »
« Reply #51 on: November 02, 2017, 10:59:59 AM »
All o-ring kit and/or separate would be perfect.
The gasket kits have several o-rings missing. Late head gasket on early cylinder + head need 8 12.5x 2mm o-rings.
Always missing the o-ring under the bearing holder beside mentioned rubber plug in this thread.
Cam holder o-rings are different if early or late due to different oil orifice. Not enough 18x3mm O-rings. DSS gasket kits has none, and most of the other o-rings missing too.
The VITAL oil pump kit is a perfect solution with all parts perfectly placed on a simple package. Really smart, IKEA should not do it better. They are otherwise really good of packing the furniture and easy descriptions without any word.
Offline Elan
    • Vital Motor Parts
76 750k
