Author Topic: Just got a cb650. A few questions.  (Read 6793 times)
Offline Nickdawg18
Re: Just got a cb650. A few questions.
« Reply #25 on: December 27, 2011, 08:09:15 PM »
ok.  another update.  I got the carb back on the bike and it took a lot longer than expected.  I think i'm gonna try to run pods.  what pods is everyone running and what jets do you guys think i should use with a 4-2 / pods exhaust?  and where do you find em?  I did get to hear the bike run today though.  she ran pretty rough and gas was still pouring out of #1 carb so they gotta come off again.  Sorry for all the questions guys, but I'm just wanting to get this thing runnin soon.
Offline ThomasD883
« Reply #26 on: December 27, 2011, 08:35:05 PM »
I think that the general idea is the k&n pods as they have built in velocity stacks. Before you go this route, try searching for stacks, pods. best oil for sohc cbXXX, best tires etc,  ;D :o . it seems to be one of those hot button topics.
Please continue to post on this whatever the result, info opn the 650 cv carbs is severly limited. God speed :)
Diesel deeds, done dirt cheap
Offline cb650
« Reply #27 on: December 27, 2011, 10:09:39 PM »
I have used unies in the past.  Like to try this at some point.
http://store.knfilters.com/search/product.aspx?Prod=RC-2362
As far as jetting I cant help you.  Did mine at a dragstrip with 6,000 ft elevation.
run the stock and go from there.
Offline Hush
« Reply #28 on: December 27, 2011, 10:18:00 PM »
The last of the 650 SOHC4's had non adjustable carb floats, if you can hear liquid in them you are screwed!
I think you will have to replace the lot, though how all 4 ended up with gas in them is a puzzle.
I had the older 79 CB650Z and a later custom 650, one float on the Z sank and I ended up buying a full set of old carbs for $50, swapped out the one float and never had any more trouble..
I seriously think you will run into trouble trying to replace the "T" pipes between the carbs as it is hard enough wrestling the 4 carbs in but if they continually spring a leak it will break your heart pulling them all the time.
Offline cb650
« Reply #29 on: December 27, 2011, 11:33:42 PM »
FYI pods make the carbs a breeze to remove.  Unless its a 81/82 I intend to drive long distances I'll run pods on them.   Not my 80.  tried it once and it was a hassle.
Yes look at the "T's" but if they look good dont mess with them.
Offline Nickdawg18
« Reply #30 on: December 28, 2011, 07:49:47 PM »
So I ran the bike today. Actually got to ride it for the first time. I was defiantly surprised how fast it is. But now I've got a new problem. After I parked it in the garage, I noticed a damn oil leak. It looks like it's comin from the counter sprocket shaft. And guess what. It's obsolete. Go figure. Anyone know where to find one???
Offline scunny
  • don't call me expert
« Reply #31 on: December 28, 2011, 09:26:30 PM »
you sure it's not coming from the shifter shaft seal, tis a common thing, and close by the countershaft seal. failing that, get the specks on the old seal, I'm sure you can find a replacement somewhere.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Nickdawg18
« Reply #32 on: December 29, 2011, 07:36:47 AM »
Well I havnt takin off the cover on the left side yet. I'll check tonight.
Offline Nickdawg18
« Reply #33 on: December 29, 2011, 03:44:10 PM »
Ok. So I went ahead drained the oil. The PO had 5qts in there. I have no clue why. But I went ahead and put 3 in and started the bike. Started perfectly. No sign of an oil leak. Sweet. The bike ran like a champ for about 2 miles than all hell broke loose. The damn thing would not stay running. It would run with full choke for about 25 seconds than die. Mind you I was 2 miles from home. Those 2 miles took forever to get back. I got plenty of weird looks too. Does anyone have any idea where to start with this one???
« Reply #34 on: December 29, 2011, 09:00:40 PM »
Got fuel in carbs?
Offline ThomasD883
« Reply #35 on: December 30, 2011, 05:16:12 PM »
+1 on fuel issue. If you had old gas you may wanna check your tank and petcock fot crap. Also i'd try taking off the gas fill cap when this happens, the vent may be clogged then fuel can't flow due to the vacuum. Iv'e actually just come in from working on my carbs, the slow and idle circuts are clogged and i cant get anything through em. Labor of love ;D.
Offline Nickdawg18
« Reply #36 on: December 30, 2011, 07:03:01 PM »
Well I can't take my cap off while the engines running. My cap is the locking style and once it's off the tank it won't forfeit the key. I've looked at the cap and I can't even tell how you would take it apart and clean it.
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
« Reply #37 on: December 30, 2011, 07:35:36 PM »
What ever happened to your floats that had fuel in them?
I have a set of carbs from a '79 that you can use. The distance between them is different than my '81., but I believe the insides are the same. Can anyone verify this?
Let me know and i'll send them out to you. Also you might be able to use the "t's" too.
                                          Doggie
Offline ThomasD883
« Reply #38 on: December 30, 2011, 10:34:07 PM »
Side note about the tees, ive got a set on my carbs i concocted from vacuum tees and hoses. I'm gonna try the aquarium tubing and see how it holds up.
Offline onepieceatatime
« Reply #39 on: December 31, 2011, 01:39:00 AM »
                                          Doggie
In addition to the different spacing, the 79 and 80 had mechanical carbs, while the 81 had 82 had CV carbs. I havent had a set of the CV carbs in my hands, but from photos they look quite different than the mechanical ones.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline cb650
« Reply #40 on: December 31, 2011, 07:33:29 AM »
Never thought to see if the flots will interchange.  might try that soon.
Offline Nickdawg18
« Reply #41 on: December 31, 2011, 04:09:00 PM »
I swapped out the floats for some without any fluid in them. No gas leak. How do you go about cleaning the fuel cap?  And I've got another problem. I can hold pipes 2-3 while it's running.  I took a good plug and checked all for plug wires and I've got spark on all 4 when it's grounded against the jug. Plugs are wet so theyre getting fuel but there is no fire. Think I should try new coils?
Offline cb650
« Reply #42 on: December 31, 2011, 06:54:15 PM »
coils ,pulse generators or ignitors.  There is 2 complete systems there so you can swap connections around and when the problem moves to 1 and 4 thats the problem.
Offline Nickdawg18
« Reply #43 on: December 31, 2011, 07:37:39 PM »
I know the coils are under the tank but are the ignitors the two silver boxes under the seat by the battery?
Offline cb650
« Reply #44 on: January 01, 2012, 12:41:36 AM »
Yes and the pulse generators are under the right crank cover the plugs are along the frame.
Offline Nickdawg18
« Reply #45 on: January 25, 2012, 12:55:08 PM »
where in the hell do you find oem parts for these bikes???  Ive looked for new pulse generators but it looks like theyre obsolete.  Anyone wanna buy this bike?
Offline cb650
« Reply #46 on: January 25, 2012, 02:15:42 PM »
They turn up on ebay.  I just sold a set last summer.   I can look around next week and see if I have anymore.
Offline Nickdawg18
« Reply #47 on: January 26, 2012, 11:29:33 AM »
Dude that'd be absolutely awesome. Thanks man.
Offline cb650
« Reply #48 on: January 26, 2012, 01:55:18 PM »
Send me a pm or I'll forget.
« Reply #49 on: January 26, 2012, 08:57:29 PM »
