Gday Roy.
how many race pipes have you seen that is that short in the hundreds of races you are referring to?
Lots, all the 1970's Yoshi's {and we were talking 4 cylinders here} were shorty, as you call it, pipes.
almost all race pipes are baffled down to about a quarter size opening.
Since when, there's plenty of racers here that will dispute that, and i have owned both the real Yoshi pipe on a 750 as well as on a 900 Boldor, no cut and shut at all and the race baffle {which i have one in front of me now} is only a couple of mm wide leaving at least 80- 85% of the rear open. I have owned race bikes and have friends that have raced since the early 70's and i can tell you that most didn't use any baffle at all until noise regulations kicked in.
but the yoshi im referring to has a bigger opening in the end. so for that one, the bends did matter.
Sorry but thats entirely wrong, like i said, i have a Yoshi race baffle that is extremely open and my pipe has the smooth bends, so did the other Yoshi pipes i have owned. You sure it is actually a Yoshi {once again i am talking SOHC4's} Even the Yoshi pipes made for the GS1000 looked the same as the Yoshi made for the 750/4 Almost identical, and short.
if it came to racing, i wouldn't slap on an exhaust from the 70's, i would put on the latest race pipe that would match what my bike puts out.
If i was racing a modern bike So would i and none have abrupt changes in the rear section of the pipe. The 1970's Yoshi pipe was fitted to bikes with around 100HP that were race winning bikes, you said your mechanic stated that the bikes wouldn't rev out which is also wrong.
i was also just trying to say that the ones with the sharp bends is better than the lossa or the carpy's which didn't even really have a baffle
That is an opinion only and doesn't prove your point either way, and the guy that was making the Yoshi pipes for Carpy is also a Yoshimura engineer that makes pipes for moto GP bikes {moto GP werks is the business} and other high end race bikes, he hand made my current pipe which just happens to have a race baffle also. You can still buy race and road baffles, they are 2 completely different animals.
http://www.motogpwerks.com/custom-projects.htmlBottom right picture is my current pipe. It has the "road" style headers, not the swooping style of the race pipe.
Yoshi makes both Race and Road pipes and i have seen at least 3 versions from the 70's.
As far as your information source is concerned, Talk to forum member Kos, he has been around these bikes since Dick Mann won Daytona on a CR750 in the early 70's, he is a world expert on these Honda race bikes, he is also the owner of M3 racing.
No Yoshi race pipe had those sharp bends in them at all, none. The Japanese pipes you refer too are the Yamiya pipes that are sold under a couple of different brand names, they are NOT a race pipe and are made for the street aftermarket, they also have 2 different types of baffles for them, one very open one and a quieter version with packing. All the race bikes that ran 4 into 4 pipes had no baffle at all either {swarbricks in the UK make them}, open pipes only. Remember that we are talking about 4 cylinder pipes here . I would love to see a picture of a modern race pipe {and i have seen plenty} that have the cut and shut rear section, including new Yoshi pipes.....
Well i am building a 1000cc beast that will be sporting one of these pipes and i expect around 100HP out of this old K2.....The pipe will have no trouble at all keeping up with the engine, changing pipes would be just splitting hairs. Drag pipes don't generally run baffles either....Some barely even run a tail pipe.....
but i can show you a race muffler from japan
You do know that most of the better race pipe manufacturers aren't based in Japan.? I can also show you race pipes with no baffle at all.....
I don't want to argue this with you but i have owned a myriad of bikes{around 40} and have had some very fast bikes and race bikes {street and drag}, worked in bike shops and pit crewed for racers and what you are telling me here just doesn't add up......
