SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
CB750 oil won't drain completely
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: CB750 oil won't drain completely (Read 1833 times)
lawhat
Full Member
on:
December 21, 2011, 08:51:40 PM »
78 CB750 oil doesn't come out as expected. Even with some kicks on the starter with the drain plug out, plenty of oil in the reservoir without any more oil flowing out.
Logged
Spanner 1
Old Timer
CB 750 K0 ( always thought it was a K1!) + CB750K8
Re: CB750 oil won't drain completely
Reply #1 on:
December 21, 2011, 08:56:43 PM »
Hey man... do you have a manual for your bike? Have you taken off the right-hand side cover yet ?
Under the r/h sidecover ( the one that covers the oil tank ) you will see that the oil tank has it's own drain plug
Logged
lawhat
Full Member
Reply #2 on:
December 22, 2011, 09:25:15 PM »
Just picked up a manual, and now realize that I'll need to drain from both the pan and the reservoir.
Any tips on making it a faster oil change? Any way to drain from one plug?
Logged
754
Really Old Timer ...
Reply #3 on:
December 22, 2011, 09:28:16 PM »
Actually 3 places, tank, pan, and filter..
Faster way..get a Honda twin....
Logged
Kelowna B.C. Canada
ekpent
To many bikes-but lookin' for more
Reply #4 on:
December 23, 2011, 07:40:08 AM »
I have also noticed that when draining the oil from the 750 engine a lot of oil is still 'trapped' inside the engine if done off the centerstand only.You will be surprised at how much more dirty stuff will drain out if you tip it very far to the left and right for a short bit and hold it then set it straight again. gets the old oil out of some trapped areas.
Last Edit: December 23, 2011, 03:03:35 PM by ekpent
Logged
lucky
Reply #5 on:
December 23, 2011, 11:21:42 AM »
It is a DRY SUMP oil system. Just like some race cars and airplanes.
Oil is NOT stored in the engine. It is stored in the oil tank.
Helps cut down on the crankshaft drag in a conventional oil pan.
Logged
lawhat
Full Member
Reply #6 on:
December 27, 2011, 05:19:10 PM »
If I'm replacing the oil pan, can I do without draining the reservoir while working on it?
Logged
bollingball
Guest
Reply #7 on:
December 27, 2011, 06:01:06 PM »
Sure you can. But why?
Ken
Logged
lawhat
Full Member
Reply #8 on:
December 27, 2011, 06:03:01 PM »
Partly laziness, and so I don't have to drain new oil and either dispose of it or recollect it.
Logged
phil71
Master
Reply #9 on:
December 27, 2011, 07:40:39 PM »
This thread is making only some sense. Taking the pan off is the opposite of laziness.
Logged
lawhat
Full Member
Reply #10 on:
December 27, 2011, 07:49:26 PM »
Replacing the oil pan is more of a necessity. It seems that it has been tapped out more than once, so I figured I'd pay the $30 for a better pan with good threads and a smaller hole (that I may have to tap again someday).
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
