SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Oil flow direction at the filter-
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Oil flow direction at the filter- (Read 2089 times)
Hannibal Smith
3rd Grade Dropout
Hot Shot
on:
December 28, 2011, 05:59:45 PM »
1974 CB550-
Before I button this last bit up- I need to confirm that the flow is "OUT" the central hole (into the center of the element), and back "IN" at the lower hole (after flowing through the element to the outside), and this is at the filter/filter housing area at the front of the motor.
Logged
Follow my build "P38 Racer" in Project section
bollingball
Guest
Re: Oil flow direction at the filter-
Reply #1 on:
December 28, 2011, 09:00:12 PM »
There is a oil flow chart in the manual at the front about page 26. Looks like it flows from the outside to the center.
Ken
Logged
Hannibal Smith
3rd Grade Dropout
Hot Shot
Reply #2 on:
December 29, 2011, 07:38:33 AM »
I don't have that flow chart in my Clymer manual- What manual are you referring to?
Logged
lone*X
Expert
Reply #3 on:
December 29, 2011, 08:05:34 AM »
Bollingball is referring to the HONDA maintenance manuals on SOHC4 website. You have to look closely to see the arrows depicting oil flow in the engine blowup on Page 36. The link below takes you to the correct manual section, just page down in the .pdf until you get to page 36.
Honda's manuals are much more comprehensive than Clymer or Haynes.
http://data.sohc4.net/SM500/HSM500550_2.pdf
Logged
Lone*X ( Don )
75 CB550K1
VTX1800C for two up cruisin.
"The best safety feature of any motorcycle is the one God put between your ears. It's also the least utilized"
Hannibal Smith
3rd Grade Dropout
Hot Shot
Reply #4 on:
December 29, 2011, 09:04:48 AM »
Thanks!!!!!!!
Logged
crazypj
I'm brill, me
Old Timer
first 100,000 miles. 1977 CB550F
Reply #5 on:
December 29, 2011, 09:09:30 AM »
Nope, comes in from the outside, flows through filter to center.
You will severly reduce surface area flowing from center out, plus, you will never be able to see anything that should be on outside if it's inside
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
