Author Topic: Honda CB750 RESTORING ENGINE THIS WINTER  (Read 4094 times)
Offline okalandnorway
  • My Honda CB 750 1974
« on: January 22, 2012, 01:36:17 PM »
Hello, Norway calling - it is winter and time for check out the engine on my 1974 CB 750.
This bike is nice, i love to ride it and in good conditions. But - I want to rebuild the engine with new bearings, cam chain, primary chain, 836 kit, new clutch, valve job, paint the cases, head.
Waiting for some parts, cleaning up parts and going for a good machine.
Offline Bowswell
  • CB750K1,CB750 K4,CB350F,CB400t1,meanstreak
Re: Honda CB750 RESTORING ENGINE THIS WINTER
« Reply #1 on: January 22, 2012, 01:45:07 PM »
Now you need the hondaman book ;D
« Reply #2 on: January 22, 2012, 01:49:37 PM »
I have the book, and that a good help.
The CB500 is my other CB.
« Reply #3 on: January 22, 2012, 01:52:35 PM »
...more...
« Reply #4 on: January 22, 2012, 01:57:58 PM »
...and more
« Reply #5 on: January 22, 2012, 02:33:54 PM »
Hi from Texas!  both of your bikes look very nice. There is an 836 kit on eBay for $110, is that what you plan to use?
Looks like you are making good progress.
« Reply #6 on: January 23, 2012, 11:53:29 AM »
Yes, I have bought one and the cylinders are bored, cases paintet this weekend and waithing for som bearings. Orders lots of parts from Cyclex and som parts from David Silver. This is my first engine rebuild and the Hondaman book, this forum and the manual are needed. Alots of good information her.
Some more pics
« Reply #7 on: January 23, 2012, 11:59:36 AM »
and some more
« Reply #8 on: January 23, 2012, 12:05:06 PM »
and some
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #9 on: January 23, 2012, 12:21:17 PM »
Nice work, I'm on my $110 Bbay 836 kit rebuild. So far so good. Looking forward to seeing your bike done.
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
« Reply #10 on: February 06, 2012, 11:41:42 AM »
I need help here, where do this 8 things which came with gasketset from Cyclex go,  I can not find any place to use this.
There have been some progress - the enginecases are back together. New bearings all over, new primary chain, cam chain, rod and crank bearing, 836 kit, new clutch and some more.
« Reply #11 on: February 06, 2012, 11:44:59 AM »
..and here is my Suzuki S32 1964 , bad picture - nice bike to, but  my Honda CB s are more fun to drive.
Offline Kevin D
  • SE Michigan
« Reply #12 on: February 06, 2012, 07:34:44 PM »
When they are used, they go between the cylinder and the head to help stop head gasket oil leaks. Check this service bulletin #42:
http://data.sohc4.net/SB750/750_42.pdf
Early bikes were built without, later bikes use the seals with a dowel on the oil return studs.
The service bulletin offers an improvement for the early motor. I tried but was unsuccessful getting the modified head gasket kit (12020-300-305) for my K1.
Looks like you have the early block and head.
« Last Edit: February 07, 2012, 03:45:04 AM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #13 on: February 06, 2012, 09:05:29 PM »
Thanks alot.
« Reply #14 on: February 24, 2012, 11:45:16 AM »
Update.
The engine back in the frame, with the cheap 836 piston, new camchaine, primary chain, new bearings in gear and rod and crank. It looks good and it was a good feeling when I touch the starterbutton and the engine fire straight up and have the lovely CB750 noise, Just love it, so now I Wait for the spring to drive it carefully.
« Reply #15 on: February 24, 2012, 11:47:19 AM »
pics
« Reply #16 on: February 24, 2012, 11:51:10 AM »
pics
