Author Topic: compression tester  (Read 2259 times)
apormarkos
compression tester
« on: May 26, 2006, 05:33:18 AM »
hi all,
i need to get one.  what size adapter or fitting or whatever do i need for use on a '76 550?
thanks,
apor
Offline Lumbee
    • My pics...
Re: compression tester
« Reply #1 on: May 26, 2006, 07:24:50 AM »
...I want to say 14mm, but don't quote me on that!  Your best bet is to bring a plug with you to the auto parts store and compare the fitting to the plug to be sure its the same size...
"I'm not a welder, but I play one on HondaChopper.com"
« Reply #2 on: May 26, 2006, 10:09:35 AM »
The Cb550 amd 750 use 12mm spark plug threaded holes.
It's in the spark plug FAQ.
The D in D7EA number indicates 12 mm threads.
apormarkos
« Reply #3 on: May 26, 2006, 11:21:46 AM »
thanks twotired, i was having no luck finding the info... my forum search skills are lacking.
i was browsing sears to see if they have a unit that fits out of the box, but they list only 14 and 18mm sizes.  are there adaptors to be had easily, or is a 12mm sparkplug hole a thing of the past or too rare for auto parts stores to stock them?
apor
Offline Lumbee
    • My pics...
« Reply #4 on: May 26, 2006, 11:50:35 AM »
...if you have an Orielly Auto parts in your area, thats where I got mine from, and it comes with a 12mm adapter...
Offline Tim2005
« Reply #5 on: May 26, 2006, 11:52:27 AM »
Has anyone found anywhere in the UK that sells a 12mm adapter? Or an online supplier?
Cheers
« Reply #6 on: May 26, 2006, 12:08:53 PM »
Knowledgeable auto parts stores can get them if not stock them.  The high volume parts movers won't care much for motorcycle bits.
I can't remember where I got my tester many years ago and there is no brand name on it!!
I put "12mm compression tester" into the google search engine and found these:
http://www.midwayautosupply.com/detailedproductdescription.asp?3074
http://www.shop.com/op/aprod-p24056608-k24-g4-~12mm+compression+tester-nover?sourceid=3
http://www.amazon.com/gp/product/B000A8N0NQ/102-9248708-0383358?v=glance&n=15684181
http://www.actron.com/product_detail.php?pid=16170
Probably can find more...
Offline Lumbee
    • My pics...
« Reply #7 on: May 26, 2006, 12:13:34 PM »
...that first one is the same one I got from Oreilly...its was around $20...
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #8 on: May 26, 2006, 02:55:16 PM »
Might want to consider a leak-down tester instead if you have an air compressor.  I've never used one myself, but will be soon  ::)
apormarkos
« Reply #9 on: May 27, 2006, 06:13:06 AM »
i don't have a compressor, but what is leak down testing?
apor
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #10 on: May 27, 2006, 08:09:30 AM »
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
Course that's for car engines, but it's basically the same.
CB750K4
apormarkos
« Reply #11 on: May 27, 2006, 12:05:17 PM »
very informative.... never heard of that test.  though i did find a compression tester at sears that had everything from 10mm-18mm adapters and compression seems to be good, ranging from 145-155.  i did get a scare when #2 was reading 100, but then i realized i had the throttle closed   ;D ;D ;D
apor
