Author Topic: Need a quick answer on a wheel spoke question please  (Read 478 times)
Offline HardcoreZ28
    • RPM Resto & Custom
« on: January 26, 2012, 10:35:55 AM »
Hey guys I'm moving along with gathering what I need for my CB750 build and as part of the project I'm swapping my stock rear wheel from a 17 down to a 16 mostly because of tire availability.  I'm going to run my stock center hub and I got my hands on a Harley 16" deep drop 40 spoke outer rim.  I know my original spokes will be too long now.  I found a set of 16" CB750 spokes online for the 69-76 models.  Will these be the correct length for my stock 1977 rear hub and the Harley outer rim?  Hoping to purchase them today so I can get them off to the plating shop to be done in copper.
Offline greenjeans
  • 1972 CB750K2
Re: Need a quick answer on a wheel spoke question please
« Reply #1 on: January 26, 2012, 11:39:37 AM »
Should be the same.   You might give a call to Buchannon spoke.  They can tell you what length the spokes actually need to be.  You just tell them your hub and what rim you'll be using and they can tell the proper length.   Then, just see if you can find out what the length of the spokes that you want to buy are.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: January 26, 2012, 03:07:07 PM »
What sprocket setup are you planning on using?
Offline HardcoreZ28
« Reply #3 on: January 28, 2012, 08:41:30 AM »
I was going to run the stock sprockets why?
