Author Topic: Wait- are the only float needle available now Keyster? 1978 CB750k  (Read 2188 times)
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
So I ordered a new float needle, thinking it was OEM. Turned out to be Keyster and had the 'springy' issue people have mentioned that effects the float level.
I thought Parts N More had oem-turned out to be Keyster, too.
Is there somewhere that offers OEM or something that works?
« Last Edit: January 27, 2012, 06:42:14 AM by Kev Nemo »
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
Re: Wait- are the only float pins available now Keyster? 1978 CB750k
« Reply #1 on: January 26, 2012, 08:39:09 PM »
 Do you know the size ? like maybe 1.5 oe 2mm .  You may be abled to find at a metal supplier or  a model shop, and cut to size
« Reply #2 on: January 26, 2012, 09:55:07 PM »
Do you mean the pin the float pivots on or the valve that shuts the fuel off?
« Reply #3 on: January 26, 2012, 11:14:58 PM »
The last ones I got from CB750Supply were not Keyster, and worked decently. You might ask them what they have today. The "Made in Japan" ones we were getting last year came from the Daiichi region of Japan, which s where that tsunami wiped out so many things for a while.
Usually, the old ones can be sufficiently cleaned to work well, because the leaks they have are caused more often by the grit on the sides and edges of the valve making the valve drag and stick. I clean them with a razor blade (gently!) and I think I have only replaced 2 valves in the last 5 years or so, cleaning many sets of carbs in the process.
bollingball
« Reply #4 on: January 27, 2012, 01:30:41 AM »
I'm not sure what you are calling a float pin ??? The pin the float pivots on??
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
Re: Wait- are the only float needle available now Keyster? 1978 CB750k
« Reply #5 on: January 27, 2012, 06:43:56 AM »
float NEEDLE
No dice on the original needle from the carb being cleaned as it is disintegrating  :'(
« Reply #6 on: January 27, 2012, 08:55:14 AM »
I agree w/ you Kev Nemo, I'd use O.E. Honda needles for those also...ANY way I could find them ;).
Offline tortelvis
« Reply #7 on: January 27, 2012, 10:05:38 AM »
You can still get OEM. Part # 16011-KCK-910. I know as I sell parts for a living and just checked Honda's dealer website.
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #9 on: January 27, 2012, 08:37:28 PM »
I think I have a used set of 4 for 25 bux including sh!t...
 sh!t = shippng handling, including taxes...
« Last Edit: January 27, 2012, 09:05:33 PM by 754 »
Offline Ernest T
« Reply #10 on: January 28, 2012, 09:13:45 AM »
$15 ea from Honda for a K4, $23 for a CB400F and $38 for an XL350.  They're available, just priced all over the map.
