Author Topic: Carb swap cb500 vs cb550??  (Read 2460 times)
Offline dergs713
« on: January 27, 2012, 10:27:35 AM »
Are carbs from a 75 honda cb550f the same as a  73cb500f..? My 73's look pretty bad, an i fell upon a set off of a 75 550 that are in good shape.  Are they universal? they look very much the same to me.
Matt
Offline Bankerdanny
  • Endeavor to persevere
Re: Carb swap cb500 vs cb550??
« Reply #1 on: January 27, 2012, 03:36:23 PM »
Based on the specs here: http://www.sohc4.net/?p=338
They are no the same. However, they may work anyway as they are the same basic carb type and use the same jet sizes.
What do you mean by 'look pretty bad'.
Offline zojirushi
« Reply #2 on: January 31, 2012, 12:19:02 PM »
My CB500 came with CB550 carbs.  They work fine.
1972 CB500K
« Reply #3 on: January 31, 2012, 01:08:25 PM »
The carbs look the same externally, but have different internal parts and adjustment settings which are matched to the induction and exhaust system.
If it's all stock, there will be some drivability issues swapping carbs.  However, both carb sets can be internally modified to work wherever.  But, it's not predictable beforehand with non-stock induction and exhaust components.   Many believe "close enough" is just fine, though.
Swapping will work.  It's up to the mechanic to determine how well.
Offline Danno
« Reply #4 on: February 01, 2012, 02:02:42 AM »
the later 550 carbs will have leaner characteristics but as two tired said you have to try them and see they are the same profile so they will go into the boots just fine
if the boots are too stiff then boil them in wintergreen oil the process is here on the forum
I have also had good luck dipping them quickly in evapo rust wiping off the excess and letting dry over night  don't dip them for more then 5 seconds at a time if they are still not soft enough after the first time then you can dip them again
Offline dergs713
« Reply #5 on: February 01, 2012, 09:40:51 PM »
Thanks a lot guys, and thanks a bunch danno for the tricks, will be putting them to use!
Matt
