Author Topic: No more stupid main jet leaf springs!  (Read 15532 times)
Offline davis96
« on: February 03, 2012, 09:41:29 AM »
My carbs were missing 2 of the main jet retaining leaf springs and the other 2 were withering away from rust. I made 2 new ones from a hacksaw blade, and that worked until one of them broke in half. Frustrated, I devised a new method to hold the main jets in place. Not trying to re-invent the wheel here, but as we all know, those little leaf springs are not available in the aftermarket and only pop up on eBay once in a great while. So here's what I came up with:
I cut a washer on one side, then slipped it on the unused upper main jet groove, and clamped it so it won't come off. This washer provides the place for a coil spring to sit, performing the same function as the factory leaf spring type retainer. So far so good as far as functionality is concerned.
'74 CB350F - sold
'71 CB500K
Re: No more stupid main jet leaf springs!
« Reply #1 on: February 03, 2012, 09:51:27 AM »
Be nice if you can find them in stainless or brass if rust is a problem. Not familiar with those carbs,never had any but hope it works out well for you and helps others. A sorta spring of a different sort.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: February 03, 2012, 12:26:16 PM »
Great idea! Got a picture of the side where you cut the washer? And what do you mean by "clamped"?
Offline mrrch
« Reply #3 on: February 03, 2012, 01:50:25 PM »
Great idea, would an e-clip work?
my build
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #4 on: February 03, 2012, 04:31:04 PM »
What an excellent idea. Congratulations on thinking outside the box. Is the spring a snug enough fit so it doesn't fall off when the carbs are still on the bike with the bowl removed?
Are you able to supply the source of the springs?
It just gets better.
This should be listed in 'Tricks & Tips'
« Last Edit: February 03, 2012, 04:32:36 PM by Frostyboy »
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: February 03, 2012, 04:48:40 PM »
Agreed!  I'll put it there now. :)
Offline davis96
« Reply #6 on: February 03, 2012, 11:41:41 PM »
Hope this picture explains what I did somewhat:
An e-clip would be ideal but I just used what I had lying around.. As for the springs, I bought a pack of assorted springs a while back.. the jets are very snug once the bowls are installed, but there's no chance everything would stay in place upside down
'74 CB350F - sold
'71 CB500K
Offline HondanutRider
« Reply #7 on: February 04, 2012, 05:34:14 AM »
GREAT SOLUTION AND ILLUSTRATION DAVIS!!!!
Offline Frostyboy
  • Circa 1951
« Reply #8 on: February 04, 2012, 06:50:03 AM »
+1 on the illustration, great work.
Perhaps a little crimping of the first coil on the spring might grip onto the jet to hold it in place to allow bowl removal on the bike if there was a need to?
We haven't met yet.
[CB550F1]
« Reply #9 on: February 05, 2012, 12:56:38 AM »
i think its a great idea,,and too simple when you think about it.
Offline MoMo
  • Ride like you're invisible
« Reply #10 on: February 05, 2012, 02:01:11 AM »
Ditto to that!  ...Larry
Offline crazypj
  • I'm brill, me
« Reply #11 on: April 11, 2012, 08:55:20 AM »
Just saw link to this post.
 Great idea, I wish I'd thought of it first  ;D
Offline 73cb500
« Reply #12 on: February 20, 2013, 06:21:28 PM »
how has this worked out i have the same problem my leaf springs are almost rusted in half that is an awesome idea also you got any tips on rebuildint these carbs
Offline crazypj
  • I'm brill, me
« Reply #13 on: February 21, 2013, 07:07:20 AM »
I've done a couple of CB350 carbs for people, no complaints yet
 It's a simple solution for a common problem
Offline blakes1975
    • n/a
« Reply #14 on: August 15, 2013, 05:49:32 PM »
Great answer to my q&a.  Were did you get the springs?
Offline davis96
« Reply #15 on: September 17, 2013, 01:34:37 PM »
IIRC, I bought a package of assorted springs at Home Depot
'74 CB350F - sold
'71 CB500K
Offline francis8766
« Reply #16 on: April 16, 2014, 01:40:14 AM »
Hi. . Can anyone post the ilustration again because its not in the thread anymore. Thanks guys
1975 honda cb550f
« Reply #17 on: April 16, 2014, 02:07:39 AM »
I still see the picture.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #18 on: April 16, 2014, 03:29:01 AM »
Weird, it says image deleted.
« Reply #19 on: April 16, 2014, 04:51:04 AM »
It also says "deleted" for me.  So here's a copy of Davis' great picture that I saved:
« Reply #20 on: April 16, 2014, 11:22:40 AM »
Thanks for posting that picture of the main jet washer 'clamping' hondanutrider.
« Reply #21 on: April 16, 2014, 12:38:03 PM »
the first post has a photo.
Offline francis8766
« Reply #22 on: April 19, 2014, 08:49:34 AM »
Thanks for uploading the illustration  :)
1975 honda cb550f
Offline swan
« Reply #23 on: May 28, 2014, 07:36:40 PM »
Thanks Davis 96 for the idea. I went to the hardware store and came up with this for my CB400F. It works brilliantly.
1975 CB400 F cafes, 1974 CB750 K4 Cafe, 1966/1976 Triumph/ Norton Triton Cafe and 1962 DBD34 BSA Gold Star Clubman.
CB750 build http://forums.sohc4.net/index.php?topic=52551.0
Offline lucky
« Reply #24 on: June 13, 2014, 11:18:00 AM »
Do not use brass next to the aluminum if you can avoid it.
Even the original 1969-70 carbs had aluminum mixture screws
and aluminum float bowl drain screws.
Stainless is a much better choice.
