Author Topic: Thoughts about those #630 chains  (Read 1303 times)
Offline lucky
« on: February 15, 2012, 08:14:31 AM »
I realized today that those #630 massive chains that were on some CB750s
caused a lot of damage because they weighed so much and when they broke
all that mass and weight and force inflicted the damage on the aluminum cases.
The newer #530 chain does not weigh nearly as much, and should cause a lot less damage IF it did break.
bollingball
Re: Thoughts about those #630 chains
« Reply #1 on: February 15, 2012, 09:29:58 AM »
If put together correctly and maintained it will not break any more than any other chain.
Some people just don't take care of there stuff. It is not the chains fault. I have never heard of a 630 breaking. Do you have a post of one doing this damage you speak of?
                                        Ken
Offline lrutt
« Reply #2 on: February 15, 2012, 09:40:57 AM »
If you break a 630 then you are seriously abusing your bike. And the weight of the chain is not what kills the cases, it's the fact that it wads up in front of the CS sprocket.
« Reply #3 on: February 15, 2012, 09:41:46 AM »
Agreed Ken, any chain will eventually fail if ignored long enough. That said a modern 520 is probably stronger than any original chain available in the day.
bollingball
« Reply #4 on: February 15, 2012, 10:46:23 AM »
bwaller very true. They don't make them like they used to ;D Thank God
                                   Ken
Online scottly
« Reply #5 on: February 15, 2012, 06:04:49 PM »
The newer chain was the 630, used on the 77/78 bikes. The 530 size was the one that tended to break and damage the case... ;)
« Reply #6 on: February 15, 2012, 06:34:06 PM »
It would take a lot of abuse to break a new 630 chain. I am sticking with the 630 when I replace mine. It is easier since the bike is set up for 630. For me it is laziness.
