Author Topic: 4-1 Exaust + Pods=What size jet needle?  (Read 1625 times)
KilgoreTrout
« on: May 29, 2006, 09:49:36 AM »
Ok. I thought I've seen people saying that 4in1 exhaust with pods will make the bike run lean unless you change the jet needles. If this is true. Here's my situation. I like the 4-1 and would also like to run pods. I think the bike (73 750) has 135 jets in it now...best case scenario what "should" I be running? I'm getting ready to rebuild the carbs and I don't really want to replace the exhaust if I don’t' have to. Right now the bike runs pretty lean (though I just synced the carbs so it might not be as bad). I've done a search and surprisingly did not find anything. Maybe some soch4.us vets could point me in the right direction?
Additional question: I thought I saw a thread about a homemade timing light in the FAQ? Am I nuts cause I'm not seeing it.
Offline mcpuffett
Re: 4-1 Exaust + Pods=What size jet needle?
« Reply #1 on: May 29, 2006, 11:54:29 AM »
hi there, i have a 76 f1 750, with 4 into 1 and pod filters,  needle is standard with clip in middle setting, and only thing i did was up jet to 125's and sync carbs been like that for over 10 years and no issues ;)  mick.
Offline Lumbee
    • My pics...
« Reply #2 on: May 29, 2006, 04:16:10 PM »
...I run straight pipes and pods on my chop, and I'm jetted at 135, so I think u'r good with the jetting.  You said u'r running lean...what are you basing this on?
"I'm not a welder, but I play one on HondaChopper.com"
eldar
« Reply #3 on: May 29, 2006, 04:38:27 PM »
have you done plug chops to see if you are actually lean? You could just need to tune your low speed air mix. 135 should work just fine, no reason to jet larger.
