Author Topic: 750 tank on a 500  (Read 4958 times)
jmanstuck
750 tank on a 500
« on: May 30, 2006, 06:30:10 PM »
will a 76 750 tank fit directly on a 73 500?  Thanks
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: 750 tank on a 500
« Reply #1 on: May 30, 2006, 09:27:26 PM »
You'll likely have to cut about 1/4 inch off the little stubs under the front tank rubber mounts, and cut the rubber down to match.  The front is narrower on the 750 tank than the 500.
I'm saying this based on my fitting an early 750 tank to my 550F.  Check which side the petcock is on as well - you want one on the left, which are I think the earlier 750 tanks (correct me if I'm wrong someone).
Offline mrbreeze
  • Not your average
« Reply #2 on: May 30, 2006, 09:47:33 PM »
You stand corrected!!!!!!!!early on the right..later on the left.
MEMBER # 257
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: May 31, 2006, 05:46:42 AM »
Ah - good to know.  I have a 750 tank with it on the right.  Never ended up using it.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #4 on: May 31, 2006, 07:45:08 AM »
BTW - for a perfect example of the 750 tank on a 550, just check out Rob Lloyd's pictures:
http://www.bikepics.com/members/roblloyd/76cb550/
One of the nicest all around 550's.
AntiRiceCRX
« Reply #5 on: May 31, 2006, 08:40:15 AM »
i kinda like that....anyone wanna trade? ;D
Offline canttuckmyshirt
« Reply #6 on: May 31, 2006, 10:13:35 AM »
I'm still new at this.. What is tyhe major difference between the tanks? is the shape or size?
72 CB500, Abe Henry wheels
77 CB550, resto-mod
04 S2000, LS1 V8
jmanstuck
« Reply #7 on: May 31, 2006, 02:28:26 PM »
God to know thanks for help here's the tank I won. ;D
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: May 31, 2006, 04:24:12 PM »
Have to agree, very nice!
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #9 on: May 31, 2006, 07:02:47 PM »
They're bigger.
550 = 3.7 gal
750 = 4.5 or 5.0 gal
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #10 on: May 31, 2006, 09:05:43 PM »
I don't think even God knows if the CB500 Twin tank you won (that's NOT a 750 tank) will fit a 500/4.  However, it's a question I and many others have asked, so let us know.  I've always liked the T tank, and have been keeping my eyes open for a local junker to test fit.
jmanstuck
« Reply #11 on: June 01, 2006, 02:57:59 AM »
  I do belive it is a 750 tank I did an image search on Google & found several 750's with that tank, one a 76 the other 78.
Thanks for the warning, but Rob Lloyd hasnt blown up. Well see, oh well only $40 shipped it will be an experiment.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Last Edit: June 01, 2006, 07:16:52 AM by tintin »
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #13 on: June 01, 2006, 10:15:14 AM »
I agree, that bike is perfect in everyway...
Offline Chris Liston
« Reply #14 on: June 01, 2006, 01:33:14 PM »
That bike has helped me out in so many ways for design process.  Rob Lloyd where are you.  He fell off the earth.   BTW, those are 750 carbs on that yellow beast too.
1976 CB550F Cafe in progress
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #15 on: June 01, 2006, 04:32:11 PM »
Well, I've never liked the way the seat 'sat' on the frame - doesn't look like it fits properly.  My only real criticism.
jmanstuck
« Reply #16 on: June 01, 2006, 04:57:10 PM »
     Heres a couple. Not a prick youre just sure. For all I know your right & it is a diffrent tank.
 The other wouldnt let me upload it & I couldnt change the format. Not the most computer oriented there is.
 Do a google image search Honda 750 it is a red tank alone with a descripton  on the 5th page.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #17 on: June 01, 2006, 08:31:12 PM »
Ok here it is.  This is a Dunstall tank.  Aftermarket racing kits.  NOT a Honda tank, and not what you bought.
http://www.classic-motorcycle-fiberglass.com/tanks/Dunstall%20CB750%20Tank.htm
And the thumbnail you posted isn't a stock Honda either - can't make it out though, and couldn't find it in your image search.
« Last Edit: June 01, 2006, 08:51:12 PM by tintin »
jmanstuck
« Reply #18 on: June 02, 2006, 02:49:07 AM »
   So anyways do you think a cb 500 twin tank is better suited than a 750 tank. As I said $40 shipped it wont
be the most money I ever wasted. I really like the tank though. I have a Mac computer so I probably get diffrent search results.
Happens at work when I try to show friends things.
« Reply #19 on: June 02, 2006, 04:39:39 AM »
I thought of getting a 500T tank to put on my 550 because there everywhere on Ebay.  I asked the same question last month and was told here that the 500T would probably not fit over the frame.  Glad you got the tank, please post if it fits.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #20 on: June 02, 2006, 06:42:49 AM »
Yeah - we're all interested to know for sure if it even comes close to fitting, so please let us know and post pics.  If it fits, you'll likely see us all running out and buying 500T tanks, the price of which will skyrocket  ::)
jmanstuck
« Reply #21 on: June 02, 2006, 01:43:37 PM »
I keep you all posted.
Offline mrbreeze
  • Not your average
« Reply #22 on: June 03, 2006, 01:27:40 AM »
It was a fuzzy pic but I will definetly agree with TinTin that it is a 500 twin tank.I had a 500      twin in the late 70's and even had to buy a used tank for it at the local cycle salvage.Fuzzy pic or not.....I can visually ID that tank!!!!I have no clue whatsoever what other bikes it will fit.
MEMBER # 257
