Author Topic: Tool for mixture setting  (Read 5847 times)
Offline lucky
« on: March 08, 2012, 04:17:50 PM »
This is another method for setting the mixture as described in the Clymers workshop manual Section  SIX.  Lucky
Do exactly as it says and use this tool.
It reads to 1 rpm!!!
You will get excellent results.
It is easier with a second person to read the numbers to you.
It works VERY well.
The tool costs about $ 47.00
« Last Edit: March 08, 2012, 04:22:00 PM by lucky »
Offline timdhawk
  • 1978 CB750K
Re: Tool for mixture setting
« Reply #1 on: March 12, 2012, 03:10:22 PM »
The product web site and some amazon reviews say its not meant for MC applications, only automotive. Have you actually used this yourself on a CB750?
In deeper than I should be...
Offline lucky
« Reply #2 on: March 13, 2012, 01:43:00 AM »
Yes, I used it myself. No problem.
Autos have 4 cylinder engines.
Offline timdhawk
  • 1978 CB750K
« Reply #3 on: March 13, 2012, 06:47:12 PM »
Well then, off to the e-store I go! Thanks
Offline lucky
« Reply #4 on: March 13, 2012, 10:30:10 PM »
On the end of the tool where it clamps onto the spark plug wire there is a white arrow and that arrow is supposed to point towards the spark plug. The instrutions do not tell you that, but it does show a drawing.
Just use #1 or #4 because they are easier to get to.
Offline lucky
« Reply #5 on: May 13, 2012, 05:16:29 PM »
I wanted add that it works best on the @1 plug wire with DYNA ignition.
