Author Topic: New Rocker?  (Read 1208 times)
Offline Milkman666
  • It's not junk, Honey - it's a classic!
New Rocker?
« on: March 08, 2012, 07:45:54 PM »
Do I need to replace this rocker? The first one I looked at, of course.
The mark on the left is through the hardened face, but there doesn't seem to be corresponding wear on the camshaft lobe. The mark on the right is less severe.
 The rocker shafts do need replacing, however, due to the well documented wear caused by the hold down bolts.
Milkman
"Everything works if you let it." - Travis W. Redfish
1975 CB750F
2006 VTX 1300C
Offline cbr954
Re: New Rocker?
« Reply #1 on: March 08, 2012, 07:53:41 PM »
If it was in my motor I would replace it.  I think it will start eating up the cam lobe. Instead of buying new you can have the old ones welded and reground.  I know Cycle X does it and I think a couple other places do too.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Re: New Rocker?
« Reply #2 on: March 08, 2012, 11:29:30 PM »
Thats the plating comming off so yes it needs changing
Offline Milkman666
Re: New Rocker?
« Reply #3 on: March 09, 2012, 05:20:02 AM »
You're supposed to tell me that that means my engine will be operating at peak efficiency and horsepower!
I pretty much knew the answer before I asked. :(
I guess I'll go check all the others.
Milkman
1975 CB750F
2006 VTX 1300C
