Author Topic: Swing Arm Bolt Grease Zerk Replacement  (Read 5453 times)
Offline Flying J
« on: March 11, 2012, 10:37:22 PM »
Just replaced my Swing arm Zerks. The old ones did not work so well and i would like to keep the swingarm lubed.
Rip out the old nipple with pliers.
Im going to use a 6mm zerk nipple i picked up at Oreillys. I used 6mm because i already had a metric tap and since its a metric bike why switch. I also like to measure how deep im drilling it out.
After you drill it....You tap it!
Clean out the shavings as much as possible. Thread in your new zerk/nipple  ;)
Give it a squirt to clear out any shavings and old grease, then slap it back on the bike.
Offline danfr
    • Apollo Motorcycles
Re: Swing Arm Bolt Grease Zerk Replacement
« Reply #1 on: March 02, 2014, 06:13:03 PM »
Same process, but with 1/4-28 thread. Thought i'd share:
Old press-in zerk:
Drilled 1/2" deep with 13/64" drill bit:
Tap. lots of oil and chip breaking:
Clean out chips, flush, clean again:
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
