Author Topic: Cylinder 4 Misfire  (Read 2295 times)
Offline Mighty550
  • 76 CB550F
Cylinder 4 Misfire
« on: March 23, 2012, 07:25:21 AM »
So before I cleaned the carbs, my number 4 cylinder was misfiring, no much so that I could touch the pipes after it had been running for a few minutes.  I cleaned they carbs (that one was a mess) and reinstalled last night.  I didnt have a chance to sync them yet, but its still misfiring on cylinder 4.  So far i've replaced the plugs, adjusted the valves (they sound much better now), cleaned the carbs, and smoothed out the inside of the intake runners.  I still have to change out the points/condensers, and set the timing.  Will this fix my misfire?  This is what the plug looked like after a quick trip around the block last night (i checked, it has good spark)
Offline nayto550
Re: Cylinder 4 Misfire
« Reply #1 on: March 23, 2012, 01:39:03 PM »
If cleaning the carbs and the other general "tune-up" stuff didn't fix it, I would look really close at the plug wire on #4.  Especially where the wire and plug boot mate up.  Seems to me that any ignition problems further down the line (points, coil, etc.) would be presenting themselves on the #1 cylinder as well.
« Last Edit: March 23, 2012, 05:29:55 PM by nayto550 »
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Offline Mighty550
  • 76 CB550F
« Reply #2 on: March 23, 2012, 02:33:04 PM »
i did the old pull the plug, plug it in, set it on the head and start it, there seemed to be pretty good spark, ill check the others the same way and compare.  I thought the same thing about the coils, points, ect., there is no issue with cylinder 1
Offline phil71
« Reply #3 on: March 23, 2012, 02:35:57 PM »
do you know for certain the bowl has fuel in it?
Offline lucky
« Reply #4 on: March 23, 2012, 05:40:38 PM »
To see if the cylinders are getting a spark, just clip on a inductive timing light onto the spark plug wires ,One at a time and look for even consistent firing.
Spark plug looks ok.
Offline mrrch
« Reply #5 on: March 23, 2012, 05:45:55 PM »
Try swapping the plug caps on #1 and #4. If it's still acting up on #4 try a different coil.
my build
Offline Mighty550
  • 76 CB550F
« Reply #6 on: March 25, 2012, 12:34:47 PM »
There is fuel in the float bowl.
I switched the 1 and 4 wires, cylinder 1 gets hot, cylinder 4 still stays cold.
SO...the carb is getting gas, the plugs, wires, and coils are fine.
I just replaced the points and condensers.  Tried to set the timing, thought i had it, started it up and it pegged to about 4k rpm without any throttle, so i guess my timing is off.  charging the battery now before I try again.  BUT, for the 5 or so seconds that the engine was running, cylinder 1, 2, and 3 headers got warm, #4 was still cold.
Offline Mighty550
  • 76 CB550F
« Reply #7 on: March 25, 2012, 12:35:56 PM »
as soon as i get the little brass adapters for my pressure gauges, and get the timing set right, i will sync the carbs.
Offline phil71
« Reply #8 on: March 25, 2012, 12:48:53 PM »
I know you don't wanna hear this, but you missed something when you cleaned the carbs. Do it again. If you can't get it cleaned ultrasonically, get a bunch of guitar strings and really go crazy in the jets and circuits .
Offline Mighty550
  • 76 CB550F
« Reply #9 on: March 25, 2012, 02:45:09 PM »
i know the jets are clear, i ran wire through them and made sure that they were clear, both the pilot and the main.  The only other thing it could be is the "pathways" for the fuel from the bowl up to the intake.  I blew carb cleaner through it when i cleaned it.  When I took it for a quick run, i gave it a good amount of throttle, and it wasnt getting much from either jet.  cant believe, or I dont want to believe, that its still clogged.
Offline phil71
« Reply #10 on: March 25, 2012, 04:04:34 PM »
look at it this way, the only other possibility is there is very little vacuum present to draw fuel in , which would be a much bigger deal. It's also a hell of a lot more likely you just missed something, especially on what you already described to be a carb that was pretty far gone.
Offline Mighty550
  • 76 CB550F
« Reply #11 on: April 05, 2012, 04:33:53 AM »
ITS ALIVE!!
Took the carb off, made sure that carb 4 was totally clean and clear, put it back on and it fired up, and the header got nice and hot.  WOOHOO!!
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #12 on: April 05, 2012, 10:26:50 AM »
Second or third time is always a charm.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
