Author Topic: Hondaman needs help!  (Read 3376 times)
« on: June 03, 2006, 10:19:45 PM »
Need some hard-to-find (it seems) parts: some 1st oversize (.25mm oversize) rings for CB750K0-5. My K2 lost a ring (broke) in a flying wrench accident today while I was turning the engine upright to finish assembling it.  :'(  That's what happens when you have to work on the floor because the garage is full of stuff...grrrr....
I prefer Honda's own rings, as they are Honda pistons, not Wiseco or other. I can pay $$ or swap parts, need rings QUICK! Summer's a-wastin'.
Help.  :(
echilds
Re: Hondaman needs help!
« Reply #1 on: June 04, 2006, 04:12:28 AM »
Not sure if this will help, but they seems to have a lot of parts...
   http://www.powersportspro.com/partsfish/login.asp
Offline Clutch Cargo
« Reply #2 on: June 04, 2006, 04:17:57 AM »
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: June 04, 2006, 07:34:58 AM »
Roule comme dans les années 70...   Roll as in the Seventies...
« Reply #4 on: June 04, 2006, 08:18:10 AM »
www.davidsilverspares.co.uk has them in the 2006 catalogue as genuine spares for £14 per set, plus shipping of course
« Reply #5 on: June 04, 2006, 11:42:05 AM »
K7 rings won't fit?
http://www.sohc4.us/forums/index.php?topic=10428.0
Since the K7 pistons are the "F" pistons (in my understanding), the CR is different. Usually, Honda changed ring faces for different CR, all the way back to the Honda 90 of the 1960s. So, I don't want to jump in to try it without having them in my hand for close-up comparisons first.
« Reply #6 on: June 04, 2006, 11:49:43 AM »
I can't vouch personally for this EBay seller, howerver he does have good feedback.
http://cgi.ebay.com/ebaymotors/NOS-VINTAGE-HONDA-PISTON-RING-SET-CB750-K1_W0QQitemZ4628899734QQihZ002QQcategoryZ35595QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
Item 4628899734
Mike
Thanks, Mike: I contacted him to check the top ring for the ".25" marking that ensures it really is the .25mm oversize. He didn't seem very sure.
Offline Clyde
« Reply #7 on: June 04, 2006, 06:18:45 PM »
 I think the K7 are the same as the late F1 rings which means they are slightly thinner.
The thinner compression rings measure 1.18mm and the earlier thicker rings measure about 1.45mm.
Sorry cannot help with any rings
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
« Reply #8 on: June 04, 2006, 08:35:35 PM »
Regds Clyde
Thanks, Clyde, that's just the sort of thing Honda does!
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #9 on: June 04, 2006, 08:54:28 PM »
Phone TOTAL SEAL. Mic the pistons for ring width and they will fix you up. Reasonable prices for machining the pistons too. I had a 67mm set cut for 1.8mm Oil rings IO 1.5mm and I think it was only $224 for the machining, rings and shipping. (complete ring sets) It was something like $10 for the setup and $2 a cut or some ridiculously low number like that?
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
« Reply #10 on: June 05, 2006, 09:32:08 PM »
Thanks to all: I finally found 4 genuine Honda sets online!
