Author Topic: Carb Rebuild  (Read 1343 times)
Offline Ernest T
Carb Rebuild
« on: March 25, 2012, 03:43:37 PM »
These were the carbs before the rebuild.
Two of the carbs had broken float mounts and one was very eroded.  I bead blasted all the parts and zinc plated the steel parts. I installed all new o-rings, gaskets, and float valves.  I left the original jets and needles--I'll replace them if I have running issues.
A very small cotter pin goes here, but I couldn't find one so I used this.
I have this one spring left over.  I cannot figure out where it goes.
Any ideas?
Offline Blackhole
Re: Carb Rebuild
« Reply #1 on: March 25, 2012, 03:49:50 PM »
The last picture is of a spring that goes on one of the choke shafts.  The carbs look great.
Blackhole
Offline tomkimberly
Re: Carb Rebuild
« Reply #2 on: March 25, 2012, 03:55:29 PM »
The remaining component looks like a hose clamp to me.
Tom
Offline KC3
  • Nature abhors a change in flux - David Griffiths
Re: Carb Rebuild
« Reply #3 on: March 25, 2012, 04:01:47 PM »
Blackhole
+1
Whether you think you can, or think you can't...You're right. -Henry Ford
Offline stereosilence
  • 1975 CB550K
Re: Carb Rebuild
« Reply #4 on: March 25, 2012, 04:11:38 PM »
Looks awesome. What did this cost? I would love to at least get mine blasted.
Offline Ernest T
Re: Carb Rebuild
« Reply #5 on: March 25, 2012, 06:56:01 PM »
Blackhole
That's what I thought, but all three of them are there, there isn't one on carb number 1.  Doh, I just realized where its from!  Carb number four had a broken float mount and I bought a carb body from a member here and it still had the choke installed so when I disassembled them I would have had four springs and only used 3 on reassembly!
Offline Ernest T
Re: Carb Rebuild
« Reply #6 on: March 25, 2012, 07:02:38 PM »
I have a blast cabinet so there wasn't any cost to blast the parts and I replated them myself too so there wasn't any cost to do that either.  Of course I had to buy the blast cabinet, compressor and plating kit in the first place.
Arrow Plating in Ft. Worth will plate 1 lb of small parts--that's the best price I've seen on zinc plating.  I'll bet they can blast or dip the parts pretty inexpensively too.  They're on the internet, their physical address is on May street in Ft. Worth.
I reused all the rusty hardware except two philips screws.  You can see the pitting on the choke lever.
« Last Edit: March 25, 2012, 07:04:53 PM by Ernest T »
