Author Topic: At long last - CB750 Clutch hub mod.  (Read 3829 times)
« on: June 04, 2006, 08:55:57 PM »
Here's a shot of my modified clutch hub, with the extra oil holes.
What you cannot see, because I could not shoot it effectively, is that the inside of these holes are chamfered - in fact, all of them are now. This really helps smooth out the clutch on CB750.
Offline chung
  • Giddy Up
    • chungfucycles.com
Re: At long last - CB750 Clutch hub mod.
« Reply #1 on: June 04, 2006, 09:33:07 PM »
I am not familiar with this mod. Please explain what this is supposed to do and how it does it? As well as any other Mods to the clutches...Springs, Friction plate material ect ::)
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: June 05, 2006, 02:36:06 AM »
Does this help with the occasional "grabiness" I've noticed, particularly in hot weather??
« Reply #3 on: June 05, 2006, 04:41:46 AM »
I switched to a 78F set up with the wave washer steel plate. Much better.
eldar
« Reply #4 on: June 05, 2006, 06:39:34 AM »
While this mod is probably more for the earlier 750s, it sounds kinda cool. I probably dont need it though. The only time I have shift problems is getting into neutral while at a stop and even that is not too hard. The only other time I have issues is from user error! My bike shifts better than many new bikes I have ridden.
Offline byidesign
« Reply #5 on: June 05, 2006, 07:47:21 AM »
Nice pic....Thanks for the info
             Bruce
82CB650SC,80CM400
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #6 on: June 05, 2006, 07:55:10 AM »
Probably a dumb question (who better to ask ;D) The holes alternate around and front to back to not compromise strenght?? And are between plate locations?? OK, that was two dumb questions.  :D
« Reply #7 on: June 05, 2006, 09:26:58 PM »
This mod reduces the suddenness of the clutch engagement, particularly in hot weather and with lower viscosity oils.
Yes, try to make the holes between the steel plates. This is easy, given that the plates have marked the hub for you already.  ;)
Also, add holes only down in the "valleys", not on the splines. This ensures that you don't damage the hub's strength.
Besides, the hub in the picture was raced 4 years, then driven to 112,000 miles before I took this picture. It's a tough piece!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: June 06, 2006, 02:16:59 AM »
Yipes, mine's not even broken in yet! Says a great deal about the durability of these machines.
