I don't use a torque wrench on them, just a cheap plug wrench, for a two stroke snowmobile or chainsaw similar to the oem type, use a craftsman 8" shaft 1/4 inch flat screwdriver for the handle and just snug it till I get a slight bow in the screwdriver, always use the same screwdriver
I don't recall ever having seen a torque spec for a spark plug, most plug maker recomend installation depending on type of seal the plug has, tapered seat or metal gasket, and then it's 1/4 turn after contact for taper seat, and half turn for gasket.
wackiest torque specs I've seen were for a VW rabbit head bolts, " torque in 3 steps to 70pounds, then 3/4 turn more"
ken.
