Thanks Bob-
Yes; all is stock as far as I can see (and know about it, and have been told about it)!
I went out and attached the slides to each carb with the settings all the same on the throttle stops - the book 'T' position.
Then I cycled the throttle grip several times and looked into the throats. I could see that all the slides were coming to a different position, some were open wider than others.
So I decided to get scientific about it -ha- and used my set of drill bits to measure the distance from the floor of the throat to the bottom of the slide where it has a curve (a pic would help? I'm just measuring how open the throat is on each)
They were all different, some would not accept a 3/32" bit, others would accept a 1/8" bit.
SO, splitting the difference, I decided to set them all to where it would just accept a 7/64" bit. Now they all stop at the same position and with the same throat opening. Hopefully they will all now get the same amount of air at idle!
What do you think?
Number of turns out, throttle screw to achieve a 7/64" opening:
Cylinder Turns of screw
...1................3.0
...2................5.4
...3................3.6
...4................4.5
I figure they are sooo different because of age. The slide or the screws have worn over 37 years.
