Author Topic: Carburator leak question  (Read 1469 times)
Offline Weeburn
« on: April 17, 2012, 04:42:40 PM »
So I finally got the bike running pretty good, haven't ridden it since last tuesday. I turn my fuel on today to ride and it starts pouring out off the carbs.
At first I thought it was hoses, they're older and hard, so I replaced those real quick but it's still leaking from the pipe that connects carbs 1 & 2 together, and where the fuel hose connects (it's a T shape).
I've repeatedly blasted it with compressed air while slightly opening the petcock, and this looks like where it's coming from (where it goes into carb 2). Is there a gasket/part that can be replaced? Also my #2 carb has always dripped slowly out of the carb drain pipe on the bottom, could this be related, like if the float bowl is filling up and the carb drain isn't enough to get it out so it comes out where it's leaking?
I'm stuck at work right now, I'd like to ride this home instead of getting a lift from my roommate
TIA
Offline Johnie
Re: Carburator leak question
« Reply #1 on: April 17, 2012, 04:51:24 PM »
The fuel T connection between carbs 1 & 2 and then 3 & 4 have a total of 4 O-rings on them. To replace those you have to remove & seperate the carbs to get at those O-rings.  If you have fuel coming out of the drain on the float bowl that means your needle valve is not closing all the way when the float rises. Could be a worn valve or incorrect float height. Tell us more about the bike. I am guessing it is a 750, but might want to confirm the bike and year for us.
« Last Edit: April 17, 2012, 05:10:26 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Weeburn
« Reply #2 on: April 17, 2012, 04:57:56 PM »
Sorry, got carried away and forgot the basic info
1974 CB550K0
Kei-hin carbs
as for the t-fitting, I'm glad there's gaskets there and it's not just some special metal fitting. Are these gaskets hard to find?
As for the #2 carb drip I did inspect and swap needles last time I had the carbs apart to see if the leak followed, it didn't, so it's not the needle. Float height is set to 22mm as per the manual. I'm wondering if the float has a leak and is sinking, I'll swap that soon to see if the leak follows then.
I'm more immediately concerned about the t-fitting, it's dumping fuel, the #2 drip is slow for now
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: April 18, 2012, 11:10:58 AM »
1974 CB550K0
Kei-hin carbs
They come as part of the carb gasket kits from Honda. Your bike is 38 YO, all your gaskets are probably brittle and cracking. It's time to pull the carbs again and replace all the gaskets and seals. Pull the needles and clean them up good with some 0000 steel wool. They can get a microscopic crud buildup that will hold your needles up and make the carb run rich.Don't forget the o-rings where the intakes bolt to the head. That's a source of vacuum leaks if the old ones are cracked and broken.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline luap
  • LAWL
« Reply #4 on: April 18, 2012, 01:57:06 PM »
For a quick fix just to get home, could try rotating the T up or down see if it wont quick leaking on you, then do what the other guys recommend
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Online CycleRanger
  • No comment about being an
Offline lucky
« Reply #6 on: April 18, 2012, 02:25:43 PM »
You have to replace the float needles!!
Not clean them with steel wool.
It does not matter if they have metal tips or rubber tips.
The rubber tips get hard and out of round. The metal ones have a shiney ring on the bevel tip and if you look at them with a magnifying glass you will see that a step is worn into the bevel face. The metal ones have to have the seat AND the needle replaced.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #7 on: April 18, 2012, 02:48:55 PM »
I don't remember saying "float needles" I am referring to the needle jets.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
