Author Topic: oil leak between 2 and 3 cylinder  (Read 809 times)
Offline Steveola
« on: April 30, 2012, 05:39:10 AM »
Started the CB750 up to check timing last night and it started leaking alot of oil out of the head fins between cylinders 2 and 3. Could this be a head gasket or something worse? It only has about 100 miles on it since an 836 Wiseco kit and Webcam. Thanks.
Offline SOHC Digger
  • I'm not an
Re: oil leak between 2 and 3 cylinder
« Reply #1 on: April 30, 2012, 06:30:47 AM »
If it's above the cylinder block to cylinder head line, it's possible that it's just a bad puck under the cam supports.  You don't need to pull the head to replace these.  I recommend using the 1194 3-bond on the pucks; it works great.
Offline Steveola
« Reply #2 on: April 30, 2012, 06:55:19 AM »
Hi SOHC Digger,
Yeah, you know I was just thinking about those rubber pucks. The leak is kind of hard to locate but the oil is coming from the head fins between 2 and 3. I didn't put any kind of sealer on those pucks when I assembled the engine. I need to work on the carbs and repaint the pipes anyway so at that point I'm about halfway from pulling the engine. Kind of a hassle but I need to have a look. Thanks for the help. Steve
