Author Topic: First start for CB750 rebuild?  (Read 1245 times)
78CB750F1
« on: June 10, 2006, 08:53:14 AM »
After several months spending far too much time in the garage, my 77 CB750 F1 is ready (I think!) to start.  I have installed new CR carbs and a new exhaust but otherwise have not touched the motor since it was running 4 months ago with the previous owner.   I am not driving it at this time, just hoping to get the motor running.  What is the best starting procedure in this case?  Are there any danger signs I should be looking for when trying to start it?
Online MRieck
Re: First start for CB750 rebuild?
« Reply #1 on: June 10, 2006, 10:16:05 AM »
Are you experienced at carb tuning as those CR's will most probably need some tweaking. Are you running them with individual filters?
78CB750F1
« Reply #2 on: June 10, 2006, 10:42:47 AM »
MRieck - I am running them with K&N pod filters and a Kerker with 1.5" competition baffle.  I have no idea about carb tuning - I ordered them from Dynoman and the owner said he would pre-jet them as close as possible to match the setup.  I am just hoping the bike will run and then I can worry about the tuning!
Online MRieck
« Reply #3 on: June 10, 2006, 07:20:34 PM »
Dynoman is a good man...it's just carbs are like women.....once you get right it's perfect. Good luck....we'll be here. ;)
78CB750F1
« Reply #4 on: June 11, 2006, 04:39:43 AM »
Last thing to do was mount the old petcock on the new tank and hook up the fuel lines but the petcock size is different between the 75-76 and 77-78 CB750 F1!  A new petcock is on its way.  First start for the rebuild project delayed again...
