Author Topic: Battery Eliminator  (Read 21038 times)
gnanner79
Re: Battery Eliminator
« Reply #25 on: July 20, 2006, 04:24:59 PM »
Hey everybody.  First time posting.  I know the discussion was a while ago, but I thought I would pipe up seeing that I am in the same boat.  I have a 74 CB550 that I have been converting to a cafe racer for the past, #$%*, really long time.  I've been checking into smaller batteries to relocate under the seat cowl and found a sealed gell YUASA battery that I think will work.  The model number is TTZ75.  Its about 3" x 3" x 4" and is 12-volts, 9 amps.
Shawn
Chicago
gnanner79
« Reply #26 on: July 20, 2006, 04:25:49 PM »
Sorry...model number YTZ75.
Shawn
Offline Kamal
  • "..but, how did it make you FEEL?"
    • MotoTherapy
« Reply #27 on: May 13, 2007, 06:47:39 PM »
I was appaled to see the wattages listed for the electrical workup.
Well, I run a 90 watt headlight, and tend to have no problems with my battery.  Though, I rarely ride my bike, and when I do, its always higher RPM. And, I never use the starter.
Nobody said anything about switching to high powered LEDs to reduce consumption.  You could theoretically eliminate almost all of the electrical load save the ignition and headlight by going to LED based lamps for the tailight, signals, and indicator lamps.
CB750K6
CB750K2 Drag Project
IT465 Yammie
KMX250 "Kawazuki" (or was it a "Suzusaki"?)
Offline cafe75-550
« Reply #28 on: May 13, 2007, 07:58:30 PM »
Check out Cycle Exchange @ http://www.cyclexchange.net/Honda%20Page.htm
If you scroll down a bit, you can take a look at their charging system. Pricey, but less than digging up a mag and it gets rid of the battery and still powers the lights. Doesn't work with the electric start, but if you're trying to save weight the starter motor weighs a ton...
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
Offline Pinhead
  • 1979 CB652-ST
« Reply #29 on: May 14, 2007, 12:59:22 PM »
Could we possibly use the permanent magnent rotor off a 550 or the likes? I've got a 650 and the rotor is problematic to say the least...
Since I posted this, I found that the 550 has the same charging system as the 750, and the 650's is virtually electrically identical. With a good electronic regulator, most of the charging problems are eliminated (see my sig).
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline edbikerii
    • Gallery
« Reply #30 on: May 14, 2007, 01:14:39 PM »
Careful, the 550 has the same type of system as the 750, but the 550 has a much lower output (fewer field and stator coil windings, I guess).
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
tmht
« Reply #31 on: May 14, 2007, 03:45:08 PM »
My philosophy on weight reduction for performance is as follows,
1. Take as much unsprung weight off as possible, in the case of sohcs, alloy wheels would give the best bang for the buck (not using oversized tires helps too)
2. Take as much weight off above the seat as possible. When I was club racing in the early 90's all of these guys were spending obscene amounts of money to get a CBR600 30 pounds lighter, when they could have cut their big mac allowance back and taken 50 off of the rider.
3. Anything that rotates above the shocks. Crank, rods, etc...
4. anything else is gravy because you are getting into diminishing returns
Offline Jim F
  • go baby go
« Reply #32 on: May 14, 2007, 09:38:35 PM »
Heres my solution
And I did buy the ARD from Terry
Just haven't had time to get it going
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline andresricha
« Reply #33 on: April 12, 2014, 02:30:23 PM »
I have a Honda CB550 and my battery has to be put on a trickle charger every few days. is there a way around this or would i just get a newer battery? i was told this is normal but every few days seems excessive?
