Author Topic: Is there a reverse-table for Honda part codes?  (Read 974 times)
Offline Raul CB750K1
« on: June 13, 2006, 02:19:25 AM »
I need some oils seals for the forks of my Sanglas bike. Problem is that Sanglas shut doors two decades ago...
As seals are pretty much standard, I was wondering if there is a way to know a Honda part code -if any- for an oil seal that measures 42 x 52 x 8. While some other parts, as bolts, form the part code depending on the measurements, oil seals are not the same. Can somebody help with that?
Best regards
Raul
Re: Is there a reverse-table for Honda part codes?
« Reply #1 on: June 13, 2006, 05:44:58 AM »
Raul if i get chance this weekend i will try and go to a shop i know and check out the aftermarket books. would you like me to get a set for you if i can as part of what i owe? Email me direct/ Regards Bryan
Offline dusterdude
« Reply #2 on: June 13, 2006, 07:56:17 AM »
there is an outfit here in the states called tcm,their part number is 42x52x8tc.if you cant find any,let me know ill get you a couple.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #3 on: June 13, 2006, 08:16:17 AM »
Thanks a lot Duster. I made a couple of phone calls and found a bearing shop that will have a set for me on thursday. I will post with the result.
They should be just fine, provided that oil seals and bearings are just standard and not brand-related. As long as the quality is good...
Raul
Offline dusterdude
« Reply #4 on: June 13, 2006, 11:04:27 AM »
im here for ya bro.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
