I'm back, fcuk it was cold outside, but I was very brave and spent an hour or so in my driveway installing the new K&N filter, then I flushed the front brake's manky old brake fluid, which looked more like muddy water than hydraulic fluid.
I couldn't bleed the brakes properly until I realised that the bleeder screw in the caliper was blocked, then the air bleed hole in the MC was blocked with crud as well, so I used a jet drill to ream the hole/s, and once I'd done that I immediately had a hard lever. (on my MC...........)
I did think about taking it for a ride, but a few big cold rain drops convinced me otherwise. Friday looks like the best day to do a decent ride this week, as it'll be 60 deg F, woohoo, that's 50% warmer than last Friday when I took it out on it's maiden voyage.
The only thing I haven't been able to address as yet is the leaking kickstart seal, a CB750 seal is 3mm smaller OD so I can't fix it today, but I've ordered a new one, and as it's only a small leak it'll be OK to ride it until the new seal arrives. Cheers, Terry.
