Author Topic: D@mn PO!  (Read 1441 times)
Offline MHansen105
D@mn PO!
« on: May 25, 2012, 07:23:29 PM »
So, I'm cleaning the carbs on my '78 750K.
Things are going fairly well, no real  problems with number 1 carb.
Then I open number 2 and look what I find!
Anybody have a clue what this stuff is?
My only guess is that there was a leak the PO could not fix and he decided to use something like JB Weld!
Now the question is...do I remove it? or leave ir?
I'm guessing that I'll be looking for a new float bowl at least.
Thoughts?
Monte
"I've always been crazy, but it's kept me from going insane!"  Waylon Jennings
Re: D@mn PO!
« Reply #1 on: May 25, 2012, 07:30:13 PM »
Yes, looks like some kind of epoxy. I would find a new bowl. Digger may have one? Or eBay.
http://forums.sohc4.net/index.php?topic=105548.msg1199418#new
Offline lucky
Re: D@mn PO!
« Reply #2 on: May 25, 2012, 08:08:06 PM »
Thoughts?
Monte
Please send me that bowl.
I will fix it.
Thanks.
Offline MHansen105
Re: D@mn PO!
« Reply #3 on: May 26, 2012, 05:08:48 AM »
Stev-O,
I've already gotten together with Digger.
He has offered to sell me one.
Lucky,
I'll send you the bowl as soon as I get a replacement from Digger.
Thanks both!
Monte
Offline brewsky
Re: D@mn PO!
« Reply #4 on: May 26, 2012, 07:16:15 AM »
Thoughts?
Monte
That's the new alternative energy source!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Re: D@mn PO!
« Reply #5 on: May 26, 2012, 07:36:47 AM »
Good to hear.  Just noticed your from TX, welcome!  I'm a few hours away on Lake Travis.
There is a great vintage bike event in Oct in Luchenbach, you should join us.
Offline lucky
Re: D@mn PO!
« Reply #6 on: May 26, 2012, 08:24:35 AM »
The PO may have been trying to close off the accelerator pump.
Offline MHansen105
Re: D@mn PO!
« Reply #7 on: May 26, 2012, 08:52:50 AM »
Stev-O,
I'll try to make that Rally!
My CB750 may not be show ready by then, but I sure hope it's road ready long before then!
Monte
Offline MHansen105
Re: D@mn PO!
« Reply #8 on: May 26, 2012, 08:56:27 AM »
Lucky,
If the goal was to close off the Accelerator Pump, it didn't seem to work.
Gas did come out when I operated the pump by hand.
Do you think that stuff will come out without hurting the bowl?
Is removing it something that needs special solvent or tools?
Now that I know this stuff is in there, I don't want to put it back into operation until it's gone.  I have sent Digger a payment for a replacment bowl, so I can take a crack at cleaning this stiff out.
Monte
Re: D@mn PO!
« Reply #9 on: May 26, 2012, 10:53:40 AM »
You may be able to get it out, depends how good the adhesion is. Why bother?
