Greg ,lucky I got Sam the man as a mentor,I reckon he is the moderator cos to me he seems to know every Honda cb rider in the world
The previous thread is my way indicating my humbleness with an average attempt at humour.
My personal favourite race is the IOM TT ( speaking of big nuts), my personal favourite bike to look at is a 70's pro stock bike, I hope you get the project up and running and get some pics to excite us.
I promised to post some numbers for different megacycle cams so here goes.
I chose a 70mm bore so MikeR can compare numbers to what hes got, I'm sure he would have done so
I guess its not so much what the numbers are but the change between the cam only changes. I chose some good numbers for the ports, would have loved to put in yours Mike. Started with a stocky just to see how the numbers compare. All numbers are engine only not back wheel.
Stock cb 750. K2 Max HP 55 @7,750........ Max Torque 36ft/lb @7,000.
Highly modified with 70mm bore:
125-25........ Max HP 128hp @8,000..... Max Torque 87 ft/lb @7,750
125-35.........Max HP 135hp @8,000......Max Torque 90 ft/lb @7,750
125-65........ Max HP 130hp @8,000......Max Torque 88 ft /lb @7,750
Torque curve flat 6,200 - 8,000
125-75........Max HP 145@9,200 HP 130 @ 8,000 ... 90 ft/lb @ 7,750
Flat torque curve 6,200 to 8,200
125-95........Max HP 149@9,200 HP 133 @8,000.....89 ft / lb @7,750
Flat torque curve 6,200 to 9,250
125X 12 .....Max HP 150 @9,250 HP 138 @8,000....91 ft / lb @7,750
Flat torque curve 6,600 to 9,200
Thinking dont hone in on the numbers but think in terms of percentages with cam only changes. If you have some bench marks to compare would be good, although most dynos are rollers not engine, throw it out there baby,
ciao Johno
