Author Topic: And in this corner is the fighter know as AIRBOX  (Read 1553 times)
Offline Magilla
  • My bike: 1976 CB750F
« on: June 01, 2012, 08:19:28 AM »
Is there any easy way to install one of these or do they suck every time?  The tubes never want to stay on the carbs, the clamps don't get very tight and basically the are a major pain.  Could it be that I have the wrong airbox?  I have a 76 CB750K and the box says 750F on it.
I can pull the bowls, remove the floats, pull the jets, clean them and replace it all faster than I can install this stupid airbox from hell.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline DJ_AX
Re: And in this corner is the fighter know as AIRBOX
« Reply #1 on: June 01, 2012, 08:28:07 AM »
If your tubes are old and stiff it is indeed a pain.
New more squishy boots make it tremendously easier!
Also, the original clamps stretch. I had to replace mine.
750F on the airbox... that's right.  The F there just stands for Filter.  ;)
« Last Edit: June 01, 2012, 08:30:08 AM by DJ_AX »
Offline CycleRanger
  • No comment about being an
« Reply #2 on: June 01, 2012, 08:29:23 AM »
All the air boxes say 750F on them.
Replacing the old, stiff, rubber intakes helps. :)
bollingball
« Reply #3 on: June 01, 2012, 08:45:35 AM »
I have read a lot of people saying this. I just don't know mine is very easy to get off and on it is a 78 750 k. Maybe some are harder than others. Just a couple of bolts and clamps and done. Same with the carbs just add a couple of cables. I guess the 78s are just a lot easier. It is what it is :) It's called wrenching for a reason
Ken
« Reply #4 on: June 01, 2012, 08:48:41 AM »
on my K8 they slide in easiest from the right side.  less things in the way.
intake rubbers are cheap, and they slide onto the carb body easier when pliable, round, and not all smashed to hell.
got my new set for ~$40 shipped.
Offline Magilla
« Reply #5 on: June 01, 2012, 10:44:46 AM »
I have new rubbers on order.  I will but new clamps too.    My rubbers are so stiff they cant come out of the box so they have to be installed as a unit.  I never had anything to compare them to so I thought they were supposed to be stiff.  Doh!!
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline DJ_AX
« Reply #6 on: June 01, 2012, 11:22:55 AM »
Yeah I was surprised when I got the new ones. The are very squishy. Much easier to get the parts out & in... and they'll seal up really nice as well!
My old ones were also split and ripped badly.
Offline lucky
« Reply #7 on: June 01, 2012, 11:28:01 AM »
The more parts all the forum members order the easier it will be to get these parts. :)
Offline DJ_AX
« Reply #8 on: June 01, 2012, 11:28:57 AM »
Also... the rubbers that connect the carbs to the engine... sadly now unavailable. :( However they are thick walled, and a soaking in Wintergreen oil has been proven to soften them up. :) Which is also beneficial to carb installation and removal.. and even more so to the running of your engine... with a good airtight seal. :)
