Author Topic: Quick Exhaust Gasket Question  (Read 1295 times)
Offline 72_350_FOUR
« on: June 05, 2012, 10:43:52 AM »
Im restoring a 72 350f, and it didnt have any ex. gaskets.  I orded some today.  Do these go on the back of the collar ?  or on the inside?.., the scehmatic isnt real clear...  I'm guessing kind of around the hole for the cylinder and then the collar slips inside ?    thanks in advance.
1972 Honda CB350F
Offline goldarrow
  • one day, i'll be an
Re: Quick Exhaust Gasket Question
« Reply #1 on: June 05, 2012, 10:48:35 AM »
I don't have the 350f. But the idea of the gasket is to keep header and cylinder sealed and the collar go over the header, then mount with flange. Hope this helps.
CB550 K0
Offline 72_350_FOUR
« Reply #2 on: June 05, 2012, 11:48:23 AM »
kind of, but what im asking is. Does the gasket go on the motor or the collar it's self ?
1972 Honda CB350F
Offline SohRon
« Reply #3 on: June 05, 2012, 06:22:42 PM »
Not familiar with the CB350, but check this thread for possible pointers:
http://forums.sohc4.net/index.php?topic=82323.0
Offline 72_350_FOUR
« Reply #4 on: June 06, 2012, 10:24:06 AM »
Exactly what i was seraching for, thanks Guys!
1972 Honda CB350F
Offline ADW
« Reply #5 on: June 08, 2012, 10:11:28 AM »
Be sure to get the old gaskets out of the head. They will likely be REALLY hard to see/you won't believe that they're gaskets, you'll think you're prying against the head itself. But get a really strong light and look at all four old gaskets and at least one of the four will end up being visible as "not a part of the head". Once they get compressed against the head and all sooty from the exhaust the old gaskets are really hard to see. But make darn sure you get the old ones out before trying to install new ones! Don't just give it a quick look and say "nah, that's just the head...no gaskets there". Look closer.
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: June 08, 2012, 10:52:13 AM »
+1
You wouldn't be the first to put new exhaust gaskets on top of the old, flattened ones.
Offline 72_350_FOUR
« Reply #7 on: June 19, 2012, 12:44:45 PM »
I will be sure to look for them , thanks for the pointer.
1972 Honda CB350F
