Author Topic: gasket and allen bolt set for 76 550-4  (Read 6022 times)
Offline CapeCafe
« on: June 11, 2012, 05:31:13 AM »
Can anyone recommend the best place to order a gasket set for my 1976 Cb550-4 K3, as well as a replacement allen head bolt kit for all the alloy engine covers?  I've listened all the learned advice from the forum members here and decided to not fix what probably isn't broke, and decided to not pull the head and cylinders.  I'm just going to pull all the covers then sand and polish the years of crud off them.  I know the screw head bolts are period correct, but I prefer the convenience of allen head.  As always, all advice is appreciated. Thanks
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
1995 Ducati 900 SS/SP
2000 Ducati 900i.e.
Offline Gman
Re: gasket and allen bolt set for 76 550-4
« Reply #1 on: June 11, 2012, 06:04:07 AM »
CC,
   If you go to the FAQ section of the forum and look in the 'Where to Buy Parts' post, you'll find the website of a member who puts together the bolt kits.  Not sure about the gasket, but you could peruse the same post and it will likely have something related.  Good luck!
G
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline CapeCafe
« Reply #2 on: June 11, 2012, 06:05:12 AM »
Thanks Gman
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
2000 Ducati 900i.e.
Offline Mcwilliams570
« Reply #3 on: June 11, 2012, 06:17:47 AM »
Got mine from alloyboltz.com..
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline PurduePete
« Reply #4 on: June 11, 2012, 11:14:27 AM »
I just bought mine from fastenal. Got them zinc plated so they look a bit more shinny than black oxide. Got them last night so can't comment on quality or anything.
PurduePete
Sent from my iPhone
1973 Honda CB500 Four - Restoring
2001 Suzuki DRZ400 Kicker - Street Legal
Offline cabrala
  • Super Duper
« Reply #5 on: June 11, 2012, 11:48:53 AM »
Scott,
I bought my Vesrah complete gasket kit from TAS for $74. While the product is good, I wouldn't recommend the vendor based on a variety of customer service quirks.
For the bolts, I have see the AlloyBoltz which look nice. I have also been in contact with Jim (FAQ as referenced above) and he has offered to put together whatever bolts I may need. PM me if you need any more specific information.
http://www.screwsforcycles.wordpress.com/
-Alex
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
Offline CapeCafe
« Reply #6 on: June 11, 2012, 12:37:00 PM »
Thanks for the information
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
2000 Ducati 900i.e.
Offline luap
  • LAWL
« Reply #7 on: June 11, 2012, 03:03:40 PM »
stainlesscycle.com 20.00 If I remember an labled very well
sirius con inc for a complete vesrah kit, an I would pay the 25 bucks more from them over TAS
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline PurduePete
« Reply #8 on: June 11, 2012, 09:14:26 PM »
Don't use stainless steel bolts. They have a chemical reaction with aluminum. It's called galvanic corrosion. It's the reason that I went with zinc coated. On an electro negativity chart they are very close to aluminum so should rust together. The machinist at the lab I work at on campus told me about it when I was talking about my bike. Did a quick search on wiki and found a decent article. Bi of a reader in that response. It saw that a website was called stainlesscycles.
PurduePete
Sent from my iPhone
Offline Deltarider
« Reply #9 on: June 11, 2012, 11:43:17 PM »
Since 1979 I've changed only these crossheads for allen:
all 16 small floatbowl bolts
all 4 bolts of the left clutch cover. I never needed to change any other bolts.
Mine is a 500 and I use an impactdriver
CB500K2-ED Excel black
Offline PurduePete
« Reply #10 on: June 17, 2012, 07:59:20 PM »
Cabrala,
I replied to your message but it was never able to send because it couldn't find you for some reason.
No fastenal doesn't have a kit. I just bought them in the size I wanted and needed. Got most installed and they look great, better than stock. Won't galvanize in the aluminum like stainless steel. I did have to shorten some though. Fastenal doesn't make a 32mm bolt so I got 35s and made them shorter. Worked well. Not sure about rust but plan to pull every month for a while to check.
PurduePete
Sent from my iPhone
Offline CycleRanger
  • No comment about being an
« Reply #11 on: June 17, 2012, 08:09:39 PM »
PurduePete
Use anti-seize when installing stainless screws with aluminum.
Offline CapeCafe
« Reply #12 on: June 18, 2012, 06:55:21 AM »
Thanks for all the advice everyone.  I ended up ordering the Alloyz 500/550 kit and it arrived promptly 4 days later.  Alloyz takes the time to bundle and package the bolts/washers for each cover in separate wrap and had very specific instructions to use ant-sieze on all the blts and blue loc-tite on the header, oil pan and any other bolts that may be prone to backing out due to vibration.
I am still waiting for the arrival of the gasket set I odered.  Since I'm not taking the top end apart, I won't be installing the head, base and valve/cam cover gasket.  With all the others (clutch, oil, etc), should I use any type of sealant when I install them?  Lastly, how important is torque when installing the cam chain cover, valve tappet covers, clutch, etc...?  I believe I have the torque specifications in the CB 500/550 shop manual that a member has made available.  The Alloyz kit come with torque specs but they seem to be focused on the bolt size not location.  As always, your advice is appreciated.
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
2000 Ducati 900i.e.
Offline akabek
« Reply #13 on: October 24, 2012, 05:58:09 PM »
Not to highjack this thread but...
I recently purchased and installed stainless allen bolts on my CB550 from Alloy Boltz.  In order to get the tappet caps back on at the front of the engine I have to remove the bolt beside each tappet whole.  Do all stainless allen bolt kits interfere with the front tappet caps?
Offline CapeCafe
« Reply #14 on: October 25, 2012, 06:00:33 AM »
I didn't have that problem, but the head is very close to the tappet cover.  I used the Alloz set on my 1976 CB550 K.  Not sure if that year/engine differs from yours
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
2000 Ducati 900i.e.
Offline akabek
« Reply #15 on: October 25, 2012, 06:19:24 AM »
I have a 1975 CB550F.  I will take another look and see how the bolt aligns against the tappet cover when both are installed.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #16 on: October 25, 2012, 04:36:24 PM »
Mine do to, prolly depends on who manufactures them.
my 1976 Cb550-4 K3
FYI A 1976 CB550 is a K2, model K3 was the next generation CB550s.
As far as gaskets you can get aftermarket top end kits which is the way to go except when it comes to the head gasket I will always use OEM honda from now on, lesson learned.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
