SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
gnashing sound comming from left side of engine while under load.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: gnashing sound comming from left side of engine while under load. (Read 2156 times)
lostmykeys
Hot Shot
on:
June 19, 2012, 04:19:34 PM »
I hope my spelling was correct on that word.
I notice a rhythmic gnashing sound comming from the left side of the engine.If I pull in the clutch it goes away.
I suspect the noise is comming from the front sprocket and chain but I just wanted to get some opinions before I buy a new chain and spockets
Logged
LesterPiglet
Old Timer
1977 CB550F2
Re: gnashing sound comming from left side of engine while under load.
Reply #1 on:
June 19, 2012, 04:22:00 PM »
Is this while the bike is stationary in neutral?
Logged
Les Ross. Certified by a Professional
lostmykeys
Hot Shot
Reply #2 on:
June 19, 2012, 04:25:48 PM »
Thanks for the response I should have said this happens when I'm riding the bike.The bike is a 78 f3
Logged
cmonSTART
Hot Shot
Reply #3 on:
June 19, 2012, 05:07:48 PM »
You should be able to get a good look at the front sprocket fairly easily. Do the teeth look/feel sharp and are they hooked at all?
Logged
1981 GL1100 Interstate
1978 CB750F Project
lucky
Really Old Timer ...
Reply #4 on:
June 19, 2012, 05:17:41 PM »
Immediately stop riding the motorcycle before it kills you!!!!
Not joking.
Logged
BobbyR
Proud Owner of the Babe Thread & Dirty Old Man
Reply #5 on:
June 19, 2012, 05:31:15 PM »
Do you notice any change in the sound when you are running a steady throttle, does it change hen you are going it throttle or when you are off the throttle and engine braking?.
Logged
lostmykeys
Hot Shot
Reply #6 on:
June 20, 2012, 10:05:11 AM »
Lucky, what are you trying to say please explain i dont want to die.
Bobby,I notice tthe sound most when i'm at steady throttle.If I pull in the clutch the sound goes away.
If i'm riding down a mountain road and coasting with clutch engaged/engine braking the sound goes away.
I only hear the sound when the bike is under load.
Logged
LesterPiglet
Old Timer
1977 CB550F2
Reply #7 on:
June 20, 2012, 10:09:02 AM »
First thing, check your chain and sprockets.
Logged
lostmykeys
Hot Shot
Reply #8 on:
June 20, 2012, 10:12:56 AM »
cmonstart,The spockets look good to me,the teeth are square not sharp or hooked.
Logged
Duke McDukiedook
Space Force 6 Star General
Wish? Did somebody say wish?
Reply #9 on:
June 20, 2012, 10:16:26 AM »
Chain condition and age?
Logged
"Well, Mr. Carpetbagger. We got somethin' in this territory called the Missouri boat ride." Josey Wales
phil71
Master
Reply #10 on:
June 20, 2012, 11:06:14 AM »
Lucky, that's pretty dramatic. You don't say if the sound is vicious and loud, or just a mild change in the sound of the engines. If it's high mileage or grossly out of sync, the primary chains could be slapping around some. They do that.
Logged
lostmykeys
Hot Shot
Reply #11 on:
June 20, 2012, 05:15:47 PM »
The sound is not that loud maybe I just need a new chain.
Logged
LesterPiglet
Old Timer
1977 CB550F2
Reply #12 on:
June 20, 2012, 05:19:40 PM »
Put it on the centre stand and rotate the wheel and check for the noise.
Check the sprocket/s teeth to make sure thay are square at the top and not pointed.
Grab the chain at the 3 o clock position on the rear sprocket and pull it away from the sprocket. If it moves a lot you need a new chain. Chain and sprockets are best replaced at the same time.
Logged
lostmykeys
Hot Shot
Reply #13 on:
July 30, 2012, 06:17:22 PM »
I am still getting this sound.So far I have checked the chain as lester instructed by taking the tension out of the chain and pulling the chain at the 3 oclock on the rear sprocket and the chain stays put.
I have taken the front sprocket cover off to see if the noise was from the chain rubbing against the cover.No change.The chain is well lubed and the sprockets look fine.The bike has a 630 chain with a 14 tooth front sprocket and a 41 tooth rear.
Logged
lostmykeys
Hot Shot
Reply #14 on:
July 30, 2012, 07:02:00 PM »
Just an idea,But could the starter clutch be making this sound?
About one in every thirty starts,my starter wont engage and makes a grinding sound.I have a new starter that I havent put on the bike yet simply because the grinding sound is rare.I have had the bike three months and have put 1500 miles in it with an average 20 miles per ride.
Logged
Really?
I've come to the conclusion that I AM a
Reply #15 on:
July 30, 2012, 10:00:50 PM »
a 14T front sprocket is on the small side me thinks. Makes for a really tight turn. At least it seams that way to me. I may have a 17T and I know I went down only one tooth from stock.
Logged
I don't have a motorcycle, sold it ('85 Yamaha Venture Royale). Haven't had a CB750 for over 40 years.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
scottly
Global Moderator
Humboldt, AZ
Reply #16 on:
July 30, 2012, 10:12:41 PM »
Is the chain rubbing on the center-stand when the stand is up? I've seen this happen with non-stock exhaust systems; the stop for the stand was part of the stock exhaust.
Logged
bytio
Enthusiast
Reply #17 on:
July 31, 2012, 01:01:03 AM »
Hi, I had a similar sound on my F2, the problem was an unevenly worn chain, so under load the tight to slack was giving the sound you describe, a new chain resolved the problem.
David
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
