We bought a '72 CB500 last year that has a CB550 stock exhaust system on it (4 into 4, '77 or newer we are told). We are just getting the bike sorted out and have now noticed that the rear brake pedal has very little room to move. The RH outboard exhaust pipe is immediately under the pedal and does not allow enough room to be operational. The layout of the pipes is different than the original. Has anyone out there dealt with this problem before? Is there another model Honda pedal that would give enough clearance? I'm reluctant to get rid of the exhaust because it is in very good shape, and a correct original would probably cost a small fortune. We have had suggestions to just bend the pedal to get clearance. It is apparently mild steel, and does not even require heat to be able to do this. Another option is to cut and re-weld. Looking for the simplest solution that would keep the bike looking as unbutchered and original as possible. I appreciate your help. I bet someone out there has worked through this before.Thanks.
