I wandered into the Harbor Freight store the other day and one of the other
toy hunters heard me discuss polishing and suggested a small right or 45 degree
angle air powered drill. The speed is controlled by throttling the air pressure, and
with the low pressure a small line can be used. One can be had for around 30 bucks
or less.....of course you need an air compressor.
Sounds like a great idea. I find they polishing with the drill revolving at right angles
to what I am holding is ideal. Unfortunately, there are lots of sandpaper pad holders
out there, but I have yet to find one that is right for small parts....maybe a two or
three inch pad. Also, where do you get small round sandpaper pads....such as sticky back...in
400 and up grit. All I can find are 150 and less.
I can't believe that everyone uses these bench grinder types with six inch buffing
wheels to do the small bike parts with many nicks and crannies. And hand sanding
is guaranteed to remove your fingerprints.....
Jim
