Author Topic: What are the sprung hatches in the 750 choke plates?  (Read 1056 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: June 30, 2012, 08:44:44 PM »
Those hatches in the middle of 750k Keihin choke plates... what the heck are those for???
Online Don R
Re: What are the sprung hatches in the 750 choke plates?
« Reply #1 on: June 30, 2012, 09:00:42 PM »
To control the vacuum when the chokes are closed.
« Reply #2 on: June 30, 2012, 09:20:05 PM »
so you cant fully over choke,they reduce the risk of flooding,,they activate once the engine fires,if you have a cold blooded engine which is hard to start in winter you could deactivate those,i just open my seat and place the cotton hat i keep there over the airbox intake, a little extra choke.
Offline grumpy
« Reply #3 on: June 30, 2012, 10:33:38 PM »
Got it.
Thanks!!
« Reply #4 on: June 30, 2012, 10:40:49 PM »
a few automotive carbs have those aswell,a mini disc held closed with a coil spring,holley and qjet have a solid choke plate,the trap door type might even be a smog/emissions thing?
Offline Bailgang
  • Scott
  • Indiana
« Reply #5 on: July 01, 2012, 04:53:57 AM »
The Qjet had what they called a choke pull off which was a vacuum actuated thingy that would pull the choke plate open just a bit the moment the engine fired up keeping the engine from flooding yet closed enough to keep the cold engine running as it warmed up. Can't remember how the Holley was because 99.9% of the ones I messed with the owners were using them for performance use and the first thing they'd do is remove that choke plate entirely.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
