Author Topic: How do you adjust the CB750 '77-'78 idle mixture screws?  (Read 13487 times)
Offline Ira
« on: July 12, 2012, 09:36:30 AM »
They're hard to reach, especially the #2 and #3.  So far, I'm wearing a thick leather glove (to avoid burning myself on the engine) and trying to manipulate a stubby screwdriver with my gloved fingertips.
Am I missing something here that would make this easier?
Re: How do you adjust the CB750 '77-'78 idle mixture screws?
« Reply #1 on: July 12, 2012, 09:43:51 AM »
Thats a tough one.  struggled with it, too.
get a 3" electric drill bit(standard), put it in a socket (forget the size) on a socket wrench...
« Last Edit: July 13, 2012, 06:56:40 AM by flybox1 »
Offline Lostboy Steve
« Reply #2 on: July 12, 2012, 09:44:49 AM »
I cut about an inch off of a stubby screw driver.  It works well for me. How much adjustment are you making? Stock they should be 1.5 turns out I believe.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline lostmykeys
« Reply #3 on: July 12, 2012, 09:57:37 AM »
 Stock is 1 3/4 out.I had the same problem and just set them cold and all seems well.
Offline Ira
« Reply #4 on: July 12, 2012, 10:02:39 AM »
I set them at 1.5, but I'm trying to adjust for a k&n airbox filter and 4-1 exhaust. Before going up a size with the idle jet, I'd like to see if I can turn the screws out enough to remove some hesitation and get the bike to start/idle easier.
bollingball
Offline 750K
« Reply #6 on: July 12, 2012, 11:40:47 AM »
I just use a slot screwdriver bit that came with my cordless drill, it's maybe 2 1/2 inches at the most in length. Easy to turn with my fingers and short enough to fit in the small confines. Or I've used the mini screwdriver bit and the adaptor bit from my socket set, it's even smaller. I find the stubby is to bulky and the mixture screw is easily turned by the driver bit and fingertips.
« Last Edit: July 12, 2012, 11:43:49 AM by 750K »
77 Cb750, 78 Kz1000
Offline micol
« Reply #7 on: July 12, 2012, 11:48:48 AM »
I use a screwdiver bit for a drill with a short piece of tubing slid over it to have something to grip.  Works petty good.  I also put marks on the tubing so I can tell how much I've tuned it.
bollingball
« Reply #9 on: July 12, 2012, 10:29:04 PM »
http://www.garrettwade.com/reversible-palm-ratchet-set/p/35N07.03/
Something like this with a two" bit works also
Ken
« Reply #10 on: July 12, 2012, 10:55:37 PM »
I made a tool for that.
Turn the gear with the long screw, and the shaft at the other end turns at a 90 degree axis.
Offline phil71
« Reply #11 on: July 12, 2012, 11:11:38 PM »
Look up "skewdriver". It'll change your life.
Offline Bfletcher99
« Reply #12 on: February 21, 2020, 09:13:38 AM »
I know this is an old post but found it while I was having the same problem, trying to fine tune the adjustments. My wife came to the rescue finding mini screwdrivers at JoAnne’s which is a local craft/fabric store. They are like nubby screwdrivers just way smaller and easier to use than a driver bit. I’ll try and post a pic. If you don’t have a JoAnne’s I’m sure Hobby Lobby or similar store would have them.
