Author Topic: Motorcycle and lightning don't mix  (Read 3322 times)
Offline Stormer
Re: Motorcycle and lightning don't mix
« Reply #25 on: June 23, 2006, 12:32:26 PM »
"Motorcycles and Lightening, very, very Frightening! Sing! Galleleo, Galleleo, Figaro!"  Jeez! we're poetic today!
BOY, THAT WAS GREAT!!!!
Sory the bad english.
Offline Jonesy
  • Shop Rat
« Reply #26 on: June 26, 2006, 07:42:16 PM »
Tires will conduct electricity. Why? The rubber is heavily loaded with carbon (which is conductive). It was dicovered long ago that adding carbon to vulcanized rubber makes the rubber much more durable. If the tires didn't contain carbon, they'd wear down like a pencil eraser and "erase" themselves after only a few hundred miles. Some extremely old cars have white tires- before this was discovered.
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #27 on: June 26, 2006, 08:02:09 PM »
The company that I used to work for insisted that we stand on "insulating" rubber
while working on among other things lasers, so we chased around and found a large
piece a half inch thick....used it for years.  When the project ended, a tech cut up the
rubber to use on his work bench and one day happened to lay the probes from an
ohmmeter on it..........dead short.  :o  That piece of rubber probably created a better
path to ground then standing on bare concrete.   ::) Woops.   ;D
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
smashme33
« Reply #28 on: June 27, 2006, 09:00:59 AM »
 We just gotta be careful when those dark CB's(Cumulonimbus) start to roll in. Maybe find decent shelter.
ElCheapo
« Reply #29 on: June 27, 2006, 07:52:01 PM »
The local news this morn was showing a 18" x 8" hole in the asphalt.
Sure it was lightining, it could have been a sohc blowing the drive chain  ;D
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #30 on: June 27, 2006, 11:33:05 PM »
Yes, it's not the tires which save you from lighting it's the steel cage that the lighting go's through. Then through the suspension parts and into the tires which are the only part of the car that touches the ground. Therefor grounding the lighting strike. Convertibles, motorcycles, ATVs and bicycles are NOT SAFE from lighting. No matter how much rubber you got!
« Last Edit: April 23, 2009, 10:18:38 PM by cb350twin »
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
jaymark18
« Reply #31 on: April 23, 2009, 08:28:02 PM »
its a question that why it not mix both of this two?we getting to mad to play it..
_________________
buell motorcycle parts
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #32 on: April 23, 2009, 09:49:59 PM »
Zombie post!!!
RUN FOR YOUR LIVES!!!
CB750K4
Offline tramp
« Reply #33 on: April 24, 2009, 03:49:03 AM »
great, one more thing to dodge on the road
1974 750k
Offline Steve F
« Reply #34 on: April 24, 2009, 04:40:24 AM »
Lightning being stopped by a few inches of rubber between the rims and ground is a myth.  Read this....
http://www.weatherimagery.com/blog/rubber-tires-protect-lightning/
